Heating & Cooling Logo
s
stephe afolabi Posted on Jul 18, 2019
I need price for outside unit for this model - Heating & Cooling
1 Related Answer
A
Anonymous
  • Posted on Jun 28, 2011
SOURCE: I need the price of
Your on the wrong site
The info is on the motor & somewhere
on the unit
You go to a supply house in your
area, where the A/C repair people go &
buy what you need
2answers
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
The compressor on my 10 yr old Rheem RAKA 037 is tripping the breaker at my circuit box. The technician that looked at it says that there is a direct short in the compressor. He says that the entire unit...
Depending on the brand and energy rating that price is probably in the ball park. I would go ahead and have the coil changed at the same time for best performance and to save more expense later.Hope this helps you. Thanks
I need the price of the outside compressor's 1/6 HP motor fan model number 13AJA30A01 WEATHERKING a/c unit, also i need the model number of that motor fan please and thank you.
on the unit
buy what you need
1helpful
We have a brand new 5 ton ac unit the part that goes outside how we got it is a long story but a good one but we need to but the other half that goes in the celing and idea how much this should cost me and...
This is called an "A" coil. You need a 5 ton "A" coil to match your outside unit, give or take 1/2 ton. The cost will vary greatly depending on the make of your unit.
1helpful
2answers
No air blowing inside the house thru vents;starts fine than stops
You are likely low on charge and the unit is freezing up. You need some with gauges to check. You should not try to run this unit until then or it will burn out the compressor.
2helpful
2answers
We have a new house and it came with central air. I have turned on the air and turned on the circuits and noticed that the outside fan on the outdoor unit was spinning round (good) now, I checked and the...
yes indeed Id have to say the motor hasent been oiled....call a hvac guy and see how much theyd charge ya for maintenance call and decide then as if its priced right for you. after the inspection he'll tell you "XXXX" is wrong and you need this or that.
Air conditioning problem. unit, compressor
Look inside your outdoor unit and find the compressor tag. It should have a model and serial # on it and a manufacturer. Then do a basic search on the net for the distributor of your compressor. However, most distributors will not sell direct to the public. You will most likely need to purchase one through a contractor. If you email me your compressor information I can help you locate and price one out.
2helpful
AC will not cool. How much should a service charge cost?
If the upstairs is working and the down stairs is not,You only need to have one unit checked,Don't assume it just needs puron(If it does,You have a leak,which cost more to locate and repair than some other likely causes)This is not something you can do yourself and is illegal if you are not EPA certified.to get a fair price would depend on your geographic location and the best way would be to call around to some local heating and air companies and ask how much a service call is.(That only tells you the price for them to came and see what the problem is,They will not be able to quote a price until they know what must be done to make the repairs.
I hope this has answered all your questions.
Please take time to rate this fixya
Inside fan runs constantly on my AC
Raise your thermosat to about 78. Also check to make sure the thermostat is set to auto and not on...
Top Heating & Cooling Experts
Paul Carew
john h
