Question about Sony STR-DE685 Receiver
The sound goes off and says "unprotected"
Unprotected shows up on the display and the sound goes off
    Problem Solver:
  • 11 Answers
Check speaker wire connections on the back of receiver
bare wires should never touch each other or the metal chassis
if all connections and speakers seem ok the problem is internal witch can go from blown power supply to shorted output devices and everything in between , and as always look for repair shop in your area, do not attempt to do it yourself, firehazard and electric shock are the things we all want to avoid ;)
Posted on Sep 02, 2009
SOURCE:
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Unprotect image
Like you protect an image, with the button with the key, you also can unprotect the image. When you have the image on the display, press the key with the key again.
Nov 25, 2013 | Nikon COOLPIX Cameras
My display says unknown format
the music you put on the player is not supported, this unit only supports MP3 or unprotected Windows Media Audio files. You can check this by right clicking the song > properties > Type of File : (make sure mp3 or unprotected WMA), if its WMA, make sure there is no license tab. My guess is your using ITUNES.. you would need to convert to MP3.
Aug 25, 2011 | Coby MP301 MP3 Player
When trying to play music the display shows "Unknown Format"
Only MP3 and unprotected WMA files re supported. If you upload copy protected WMA files or any of the iTunes AAC formated songs, they will not play. All purchases from the iTunes store have to be converted to MP3 before they can be played on this player.
Also, some older MP3 players will not be able to play MP3 audio encoded at high bitrates.
Apr 21, 2011 | Eclipse CLD2BK MP3 Player
I put my memory card into my Kodak EasyShare C143 digital camera. I press the review button, but all that comes up is that the file is 'Unrecognised'. One out of the three pictures is unprotected, but the...
It sounds as if the card was not formatted for the camera before it was put to use. My suggestion is that you attempt to download the images that you do have to the computer, then format the memory card. Always format a new card and after each time you download pictures from the card to the computer.
Dec 28, 2010 | Cameras
I accidentally protected a picture on my camera nikon d60, how to unprotect it and delete it
There are 2 ways to do it. Firstly you can format the card - this will delete all images, including protected ones. Second method is to display the image in full frame view mode (or highlight it in thumbnail view) and then press the AE-L /AF-L button. This will remove the protection - or protect an unprotected image.
Hope that helps
Aug 01, 2010 | Nikon Cameras
I have managed to put a lock on my memory card in my camera... (it is on protection mode and dont know how to get it off as i want to delete all the pictures on the card. I have the old pentex optio wpi...
If your pictures are on the SD card in your camera, many of the sd cards have a small micro switch on one edge that will lock your card... you may want to pull it out of the camera and make sure that the physical lock isn't set..
Dec 02, 2009 | Cameras
Cant do anything the padlock sign is on and I dont know how to remove it so I can upload my pics to pc thanks averil, greece
It sounds like you have put the photo's into a protected state.
According to Pentax guides, you may have inadvertantly set it to protect all photo's. To release this you need to:
Set the mode dial to >
Press the key/padlock sign button twice
Select Unprotect using the 4 way control pad
Press ok.
To unprotect a single photo
Set the mode dial to > and select the individual photo
Press the key padlock sign button once
Press ok.
Hope that helps!
Nov 18, 2009 | Pentax Cameras
Clock problem
try holding hte clock/set start button in for 3-5 secs, it sounds as if youve accidently turned of the clock display. .. a common issue especially after turning clocks back.. its a built in feature for people with too many clocks in kitchen, they allow you to turn off the display.
Nov 04, 2008 | KitchenAid KERC507 Electric Kitchen Range
Sony STR-DE685 Receiver Logo
146 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
