I have a Android tablet. I forgot the locked screen pattern and username and password. Tried the factory resetting, but wheni hold down the power button and volume button the tablet cuts back on to the unlock pattern screen. Please HELP.
Hi Juanita Garris, I want to help you with your question, but I need more information from you. Please Call Customer Service & Support For Help Call 1 8O5*465*751O Toll Free 24x7Hi Juanita Garris, I want to help you with your question, but I need more information from you.
You can't post conmments that contain an email address.
If you forgot the passcode to unlock your Prestige Elite 8QI tablet, you can try the following methods:
Use Google account: If your tablet is linked to a Google account, you can try to unlock it using the associated Google account credentials. On the lock screen, tap "Forgot Pattern" or "Forgot Password" and follow the instructions to enter your Google account username and password.
Factory reset: If the above method doesn't work, you can perform a factory reset on your tablet to remove the passcode. Please note that this will erase all data on your tablet, so make sure to back up your files before proceeding.
To factory reset your Prestige Elite 8QI tablet, follow these steps:
Power off your tablet.
Press and hold the Volume Up button and the Power button at the same time until the logo screen appears.
Release the Power button but continue holding the Volume Up button until the Android System Recovery menu appears.
Use the Volume buttons to navigate to "Wipe data/factory reset" and press the Power button to select it.
Use the Volume buttons to navigate to "Yes -- delete all user data" and press the Power button to confirm.
Once the reset process is complete, use the Volume buttons to navigate to "Reboot system now" and press the Power button to restart your tablet.
Your Prestige Elite 8QI tablet should now be unlocked and ready to use.
How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
Oct 18, 2015 - How to bypass Android's lock screen pattern, PIN or password ..... Hi can anyone help me I have lost my android tablet device in my bedroom ...
www.pcadvisor.co.uk > ... > How to unlock an Android phone/tablet
Feb 4, 2013 - But what do you do when you forget your own access code? ... Choose a new screen lock option, such as a pattern or PIN, then enter a code. ... If you've locked your Android smartphone or tablet with a PIN or password, ...
Turn your tablet off and remove the SD card, if there is one.
Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Try this: Turn tablet off. Hold down volume up button and press power on button - continuing to hold both buttons down until the screen says something like "booting in recovery mode" (then touch the android robot image) or gives you options to do a factory reset. Do a factory reset and then reboot tablet normally. Be aware that a factory reset will wipe all user data from the tablet. Next time I would write down your selected password and put the paper in your wallet or purse.....
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here... http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Hold down the power button and the up volume button at the same time for about 30 -60 seconds. The device should go to the factory reset screen if not use power on button to get to the screen. You will lose all data stored. I know this works as I have just done the same to my nieces as she forgot her password.
