Samsung TX card AH 81 found with SamsungTV and Samsung DVD, Tuner....what is this for and how is it used? Can this be used to view something from my tablet on the tv monitor?
The Samsung TX card is used to send part of the audio signal from the main unit to the wireless module that controls the surround sound (rear) speakers for a Samsung Home Theater system. It isn't going to act like a ChromeCast device for your tablet.
The Samsung AH81-04177J (SWA-4000) is only compatible with a small number of Samsung Home Theater systems. see http://www.samsungparts.com/Products/Parts_and_Accessories/PID-AH81-04177J.aspx . One of the supported systems is the Samsung HT-BD3252, https://www.samsung.com/us/support/owners/product/blu-ray-home-theater-ht-bd3252-series . See the manual of the home theater system for more information: http://downloadcenter.samsung.com/content/UM/201104/20110419185210639/HT-BD3252A_XAA_0807[1].pdf .
I hope this helps.
SOURCE: Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
SOURCE: ACER LCD Monitor display is too bright!
I have my husband's hp monitor and thought I was going to go blind. I turned down the brightness to 0 and it still didn't help that much. I decided to turn down the contrast and it worked. Hope this helps.
SOURCE: Samsung DVD (1500) Remote problem.
Try to reset the blu ray player's remote control.
Remove the batteries and hold down the POWER button on it for 30 seconds.
Then replace the batteries with fresh ones
SOURCE: Acer LCD Monitor AL2671W - screen too bright!
I had the same problem with my TV when I purchased it used. Select the input you are having troubles with and enter "Service Mode" by pressing and holding the "VOL - " button and "CHAN + " buttons on the TV, simultaneously until the screen flashes red one time.
At this point you will be in service mode. Pressing the "MENU" button will open a service menu, which is different from the typical user menu. From the service menu you can further adjust your image settings until you have a decent picture.
Initially my VGA input looked terribly bright and washed out. Now it looks incredible!
SOURCE: DVD recorder has stopped picking up a signal from the tv.
Double check connections first and try using the factory settings reset, before replacing the card.
