A few thoughts:
Unplug the USB cable from the computer but leave it plugged into the camera. Make sure you have the volume turned up on the laptop and plug the USB cable in. Did you hear the "baloop" sound Windows makes when a USB device is connected? If not the cable may be bad. Test it with another device if you can.
If you are sure it is downloading and just can't find the photos do a Windows search for .jpg. You'll likely get lots of photos, see if any of those are from your current batch. Right click a current one and choose "properties" it will show you what folder the images are in.
SOURCE: Nikon coolpix L11
well have you got a card reader? if you have then plug the memory card into the wright socket and see what happens
SOURCE: Mac doesn't recognize my Nikon Coolpix
Use a cardreader to download your pictures. Download them to a folder you create on your desktop. From there, you can do anything you want with them.
SOURCE: I attach Nikon CoolPix S550
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
SOURCE: I can't download pictures from my camera to my
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
