SOURCE: Needle won't move on Bernina 930
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced. This is a simple fix and it happens all the time on those machines. Take it to your local Bernina dealer for a standard service. Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
SOURCE: needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
SOURCE: My machine Bernina 830 does not run.
Rose, most likely your machine is gummed up and needs oiling. A product called Tri-Flow is best. It can be purchased at most any hardware store. Or just use normal sewing machine oil. Open the top and put a fair amount of oil down behind the knobs and let it soak in. As it soaks just wiggle the knobs or turn them little by little back and forth until they free up. Don't force anything as something will break.
Good luck
SOURCE: bernina 830 old style need replacment part -under extention table
The clamping yokes for Bernina sewing tables for models 830 and earlier models were hand fitted parts. Welding this may change the geometry so that the table may not fit at all. Additionally the material is diecast AL, not cast iron, and may or may not accept TIG welding applications.
