Wii fit asks this every few days at the start of the training, especially if your weight changes drastically. Try this: Use your Mii but instead of weighting yourself, ask someone alse to do the BMI test for you. If the weight is dramatically different, Wii fit will ask you to change your goal. Hope this helps.
theres plobley a problem in the game try it again see if it works if not sand me a letter saying your name adresses thats it and i will come check it out
We had that issue one game and the problem was that we had multiple users all using the same Mii character but weighing between a range of 60lb between people. Because the fit uses weight to determine if you are actually jumping (since you're not supposed to break contact with the fit board) if one user weighs more than the previous person who's weight was used as the calibration, the second person will seem to be in a constant 'jump' state. Try resetting the weight for the Mii you're using, or just recalibrate between users. This totally solved our problems!
If you're using the Wii Fit on carpet, you need to use the additional legs that came in the package. Simple pop 'em on and they should (hopefully) fix the problem.
Sometimes the silicone skin can have an effect on the Wii Fit Balance Board if it gets pinched. Make sure that it is not interfering with the the total movement of the top portion of the Wii Fit balance board and the space between the top and the middle of the unit. If there is any obstruction, refit the skin on the balance board.
In the US version the weight limit is 330 lbs. In Europe and Germany it is 300 lbs. Not sure how to get around it yet. I'm sure some people have creative solutions.
