What happens if you move the DVR off your Sony TV and put it onto your wife's TV (swap DVRs). Does the problem follow the DVR?
If it does, then you are looking at something common with the DVR, since the expander appears to work just fine on another dvr. If it problem doesn't follow the DVR when swapped, you may be looking at a ground loop issue.
Ground Loops occur when different devices are plugged in at different points. Ideally, everything should be plugged into the same power strip, or wall outlet. But, when things are plugged into different points, noise can pop up due to the difference of electrical potential on the grounds of the equipment, and even the neutral conductors. This can occur even when using an extension cord that is plugged into the same strip. Also try using a different power strip temporarily to see if that improves things as well.
