Onkyo DV-SP302 DVD Player Logo
Posted on Sep 02, 2009
Ongkyo dv-sp302 dvd/cd player,disc tray open
I have an Ongkyo dv-sp302 dvd/cd player. The disc tray won't open. I already tried to off the unit then on again but it still won't open. When I press the open button of the unit or the remote, it will just display "open" but it won't. Please teel me how to trouble shoot this. Thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
268
Points
Hi
I know the reply is a bit late but I had a similar problem.
The problem is with one IC close to where the motor wire are connected. This particular IC overheats and that was causing a malfuction. So I have installed a small heat sink and now all is well.
Hope this works for you too
All the best - Clayton
Panasonic BTT268 tray wont open
Dear Scott,
If there is a CD stuck inside a CD/DVD reader, you could try using a medium sized paper clip straightened up. Insert it in the small hole in the front of the DVD player bezel and push it till it opens the mechanism. Please, have a look at: http://www.youtube.com/watch?v=fa_4CsS7MKw
The problem can also be caused if one of the rubber band that moves the DVD drive "door" has dried out, or even if the power supply in not properly connected to the drive.
Hope you may find this info hopeful!
Best regards,
Miguel Luiz Martins
Kenwood CD/DVD player moder DV-605 tray is jammed, how can I manually resease it
you have to play the disc in another player or you can change the type of the disc.. the player is just not compatible with your disc.
1helpful
Tray won't open
by just resetting the software will not work this is a mechanical problem this usually happens on players that is not use for a long time or improper closing of tray..fixing this kind of problem requires opening the cover of the unit..you need to lubricate all moving gears and parts by putting enough amount of lubricating oil..you have also need to assist the motor manually by helping it to push the tray out just gently pull the tray with your hands during a eject command on the unit clean also the limit switches of the tray make that contact are properly working..good luck!
2answers
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Is a electronic cuicuit diagram available for a onkyo dv-sp302 dvd player
ftp://wintex.kiev.ua/%D1%81%D0%B5%D1%80%D0%B2%D0%B8%D1%81%20%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B/Onkyo/DV-SP302DVDplayer.pdf
Here is a link to the pdf file of the service manual which has circuit diagrams. You will need Adobe Reader to open the file (can download for free from adobe if you don't have it already)
1helpful
Tray will not open on my dv-605
Solution: Unplug power from wall. (Don't just turn off!) Next: Remove exterior case. Now gently turn the CD changer clockwise one position. Power up and try again.
I had this same problem after unit appeared to have froze up when unpacked from a shipping box. The CD changer had got off track and by gently moving the CD changer 1 position it fixed the problem. Works fine now.
Best of luck,
Z-Dawg
2answers
2answers
BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Top Onkyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
