I have a Dell 1815 All in One Printer. It gives me an error message which says "No paper" even when the paper is full. I have tried clearing the printer's settings and then turning it off and back on, but that did not work. I also checked to make sure that the paper sensor is swinging freely (it is). Do you have any other suggestions for how to fix this problem? It obviously won't print when it thinks there is no paper.
Your default paper source might have been changed.
Go to Menu > Copy Defaults > Select Tray and switch it to one of the trays.
Multifuncional DELL MFP1815I have the same problem... when I use the MPF the printer work. by the way, I changed the paper sensor in the tray 2 but the problem still. any Idea?
Most likely the printer is asking for paper in the Manual Printer Feeder (not the tray). Try put paper in the MPF.
CHeers
