I was recently given a GE washer model #WJSR2080V3WW that does not agitate. It fills with water, spins and drains and I can hear the cycle while it should be agitating but there's no movement.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Followed below instructions andfixedproblem in a few minutes after getting part. This advise saved me at least $2500.00 as my wife had her eye on one of the steam models (washer and dryer with stand). Before I found this solution I had contacted a repairman and was advised that it was probably not fixable.ess than $20.00 and a little effort solved the problem. Thanks
