Question about Maax PALACE DROP-IN BATHTUB - 100082-000-B - Biscuit
Maax bathtub Palace model Error code C01 jets don't turn on.
I have a Maax bathtub Palace model and the jets will not turn on. Error code C01 is displayed. Any ideas or help with error codes?
  • 10,865 Answers
First of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
Posted on Sep 01, 2009
SOURCE:
Maax c02 error
[PDF]WHIRLPOOL BATHTUB OWNER'S MANUAL BAIN ... - Maax
www.maax.com/~/media/.../10050073_2009-04-17.p...
Translate this page Never operate the whirlpool system if there is less than 2". (5 cm) of water over the highest whirlpool jet (except for the back jets) or if the bathtub is empty.
Maax co2 error Bathtubs & Whirlpools Questions & Answers ...
www.fixya.com > Forum > Tags > co2 error > Bathtubs & Whirlpools
Maax bathtubs & whirlpools co2 error related questions and answers. Ask your Maaxquestions. Get free help from bathtub and whirlpool experts.
Maax bathtub c02 and e06 error - Fixya
www.fixya.com/support/t19321104-maax_bathtub_c02_e06_error
Aug 10, 2013 - maax bathtub c02 and e06 error - Maax URBAN 6032 HYDROFEEL AEROFEEL ... Jan 18, 2013 ' Maax Adagio True Whirlpool System.
How to Troubleshoot a Maax Tub ' eHow
Jan 05, 2016 | Maax Home
Maax elite spa
Here is a link to some error codes you can check to find your code.
Error Codes
Rod
US Parts Center
Jun 22, 2013 | Home
E-01 error code
What system is this on? Do you know the control box number under the bathtub?
Rod
US Parts Center
We locate the "seemingly" impossible...
888-521-6183
Jan 18, 2013 | Maax Adagio True Whirlpool System...
Where is the filter located on a maax whirlpool drop-in tub
As far as I know you do know have a filter. I have read my instruction manual and it does not mention a filter at all. I have the Topaz 6036. To clean it you are to fill your tub with water and put in dishwasher detergent and let the tub run for a few minutes. You can also add a small amount of bleach.
Dec 17, 2011 | MAAX PALACE 6-JET HYDROMAX DROP-IN BATHTUB...
I have a MAAX Hydromax - not sure about the model #. The blower and circulation pump no longer engage. At first the problem was intermittent now it will not work at all. I tried to trouble shoot the...
yes. search US Parts Center for a solution. They will want to know the model number of your pump and model number of the controls you have.
Most likely it is a bad circuit board in the control box that turns the pump/blower on/off.
Jan 25, 2011 | Home
Maax infinity hot tub error code clfl dont have the manual
Found at http://www.maaxcollection.com/Produits/ProductInfo.aspx?cat=1&fmly=1315&mdl=1851&sp=2%3b5%3b215
Click on "Installation Guides" under the "Downloads" blue highlighted box. Then download the "Whirlpool Installation and User Guide".
Quite sparse on error codes, but p19-23 have some.
...soon to be owner/user Maax Infinity bahtubber
Jan 26, 2010 | Maax INFINITI HYDROMAX AIRPOOL II CORNER...
Hydro maax wirlpool bathtub Model # J6061 Pump will start
Can either be a bad motor or if the motor has a capacitor, it needs to be replaced. I would call a service professional to come out.
Apr 05, 2009 | Maax Home
MAXX code E01, jets don't work
well first of all i have to assume that this tub is equipped with jet's on the floor and lights,if not then there's no reason for it those buttons to light up, now if it is equipped with these features and your getting a error code all this means is that this tub need to Re Configured to run this type of system,this is something a tech needs to look at because you wouldn't be getting error codes if the tub was configured wrong the reason your getting error codes is because something isn't plugged in correctly at the control box and the computer detected a fault.
Justin 503-547-3483
Mar 13, 2009 | Maax Calla 6042 Bathtub - 101058-000
I have a Maax Calla tub that the led is flashing E06 and it has been flashing for three days.
What does this control look like? Can you email us a photo of the control?
usually that error code is a water level problem.
Jan 10, 2009 | Maax Calla 6042 Bathtub - 101058-000
Maax PALACE DROP-IN BATHTUB - 100082-000-B - Biscuit Logo
2,107 people viewed this question
Top Maax Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you a Maax Home Expert? Answer questions, earn points and help others
