1998 Pontiac Grand Prix Logo
Posted on Sep 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i remove the front seats of a 1998 Pontiac Grand Prix?
  • Anonymous Mar 29, 2014
    Specs on front and rear rotors 1998 grand prix
ZJ Limited
Level 3:
  • Pontiac Master 17,989 Answers
  • Posted on Sep 01, 2009
ZJ Limited
Pontiac Master
Level 3:
Answers
17989
Questions
0
Helped
14455853
Points
60858
On W-Body vehicles, the front seats are secured to the floorpan by two front hook attachments and two rear bolts installed to nuts welded to the floorpan.
The manually operated two-way front adjusters provides only fore and aft movement of the seat. When the seat adjuster handle located on the front seat is pulled up, the seat adjusters unlock, permitting travel of the seat. When the seat is in the desired position and the seat adjuster handle is released, the seat locks in place.
A power operated six-way seat adjuster is available. The adjusters are activated by three 12 volt, reversible, permanent magnet motors with a built-in circuit breaker. The motors are energized by a switch bolted on the seat side panel.
The three motors drive the front seat and rear vertical actuators and a horizontal actuator. When the adjusters reach the limit of travel, torque is absorbed through the rubber mounted grommets located between the motor and the support. An overload relay is provided in the circuit and will open should excessive stall be applied.
The optional 60/40 split bench front seats have seat back head restraints on the driver's and passenger's seat back. The head restraints are designed so they cannot be removed from the seat back without first inserting a small rounded tool inside the head restraint support tube to release the locking tab. The 60/40 split bench seat is equipped with a reclining mechanism on both the driver's and passenger's side. The recliner lever is located on the outboard side of the spring cushion. When the lever is pulled upward, the spring loaded dual linear reclining unit located in the cushion frame is released, allowing the seat back to be pushed rearward or allowing the spring loaded reclining unit to bring the seat back forward.
Bucket seats are equipped with manual reclining mechanisms. An optional six-way power seat adjuster is available. Some bucket seats are equipped with inertia seat back locks. This system allows the seat back to fold forward without requiring the occupant to release a locking lever or access to the rear seat area. During a sudden stop or deceleration, or if the front of the vehicle is nose down, the inertia system of the seat back lock will engage, holding the seat back in its rest position. A release lever is provided to allow manual release of the seat back lock when the vehicle is in the nose down position. The release lever is located at the lower rear outboard corner of the seat back.
Some W-Body vehicles (notably Pontiac coupes) have passenger front seats equipped with an E-Z Entry device. This is actuated, in an unoccupied seat, by completely folding the seat back forward disengaging the adjuster, and sliding the front seat forward to gain access to the rear seat area. To return the seat to its normal position, return the seat back to its rest position, and slide the entire seat rearward, engaging the adjuster.
W-Body rear seats are available in several styles including a rear seat with an integral child restraint device.
  • ZJ Limited
    ZJ Limited Sep 01, 2009
    REMOVAL & INSTALLATION
    Front Seats
        Remove the adjuster track covers, as follows:
            Unsnap the track covers from the front of the adjusters (manual and power adjusters).
            Remove the track cover screw from the rear of the adjusters (manual seat adjuster only).
            Unsnap the track covers from the rear of the adjusters (power adjusters).
        Move the seat to the full forward and full up position.
        Remove the retractor side seat belt anchor from the seat.
        Remove the seat adjuster-to-floorpan bolts.
        Detach the power seat electrical connector, if equipped.
        Detach the seat belt reminder electrical connector, driver's side only.
        Disengage the front hook attachments.
        Remove the front seat from the vehicle.
    NOTE
    Be careful not to damage the interior and painted surfaces when removing the seat assemblies.
    Front seat, side trim and adjuster assembly arrangement-2000 Intrigue shown, other vehicles with 6-way power seats similar
    To install:
        With an assistant, install the seat assembly into place and engage the front hook attachments.
        Attach all electrical connectors.
        Operate the seat to the full forward, full up position.
        Install the retractor side belt anchor to the seat.
        Install the adjuster-to-floorpan bolts and tighten to 18 ft. lbs. (24 Nm).
    WARNING
    Do not overtorque adjuster-to-floorpan nuts as a hard seat travel problem could result.
        Install the adjuster track covers.
        Cycle the seat (six-way power) to ensure proper operation and synchronization of the left and front adjusters.
    I hope help you with this (remember rated this). Good luck.
Front seat removal in 1976 Pontiac Grand Prix
There are only 4 screws and bolts to hold down the seat. Only the screws will come loose.
1helpful
Can I replace my 98 grand prix driver's seat with
You can replace it as long as the one you are replacing is the same set-up. If you have a manual adjusting seat and replace it with a power seat it will fit but you wont have the hook ups for it. Also make sure if it is a bucket seat (single person) you dont replace it with a bench (3 persons fit in front) seat or you will run into problems with the center console and shifter. vice versa may bolt up but there will be a gap between the 2 front seats
How do you get to the Front bolts on the front seats of a 2005 Pontiac Gran Prix
Move the seat all the way back and the front bolts will be accessible.
1helpful
2answers
Can you go thru the back seat to replace a fuel pump on a 98 pontiac grand am... do not have money to have gas removed and tank dropped. need help asap.
No I dont think you can as I cant on my 98 oldsmobile achieva and they are basically the same car. Almost all parts are interchangeable between the two.
1helpful
Remove shifter knob 1998 pontiac grand prix
Hello! It's best to put the gear shifter all the way back into the 1st gear. After you do this look on the front of the shift knob, just above where it meets the shifter's shaft you will see a horizontal slot - inside this is a clip. You will need a small flat-bladed screwdriver, or a mechanic's pick to pull this clip out, but once it is removed the shift knob will come off by pulling it straight up.
Thanks for using FixYa!
4answers
Need to know how to remove fuel pump from 1998 grand prix
You will have to drian your fuel tank and drop it down to access the fuel pump and sending unit inside the tank.
2helpful
2answers
1998 pontiac grand prix starter
disconnect the negative battery terminal first then disconnect the positive treminal so there are no accidents, raise the car safely go underneath & remove the starter cover should be 3 10mm bolts holding the cover on then remove the 2 through starter bolts 15mm then disconnect the + battery cvable from starter then disconnect the solenoid wire should be a 7 mm bolt. good luck
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
