Question about Acer Computers & Internet
Acer IconiaA1 stuck on erasiing after factory reset
  • Patrik Parker Jul 18, 2019
    Hi George Weir, I want to help you with your question, but I need more information from you.
    Please Call Customer Service & Support For Help Call 1 8O5*465*751O Toll Free 24x7
Hello I have an acer tablet with windows 10 and its been stuck undoing changes for about 4 days how can I get in to restore it
try this link might help. Step 1 Acer Iconia Tab B1-711 3G - Factory / Hard reset / Password Removal
  1. Power off the tablet. Press and hold the Volume Up and the Power button. ...
  2. [SD Image Update Mode]
  3. wipe data/factory reset.
  4. Yes - delete all user data.
  5. Reboot system now.
  6. Your tablet will reboot and go to the Welcome screen.
Acer Iconia Tab B1-711 3G - Factory / Hard reset / Password Removal ...
https://www.ifixit.com/Guide/Acer+Iconia+Tab+B1...Factory...reset.../23792 acer tablet restore to factory settings Google Search
Oct 18, 2017 | Acer Computers & Internet
I done a factory reset on my acer laptop and for about 30 or 45 mins now its been stuck on the last step installing sysprep factory mode with three dots behind that keeping counting. should i worry ?
Leave it overnight. If it it still doing it, reboot and see what happens. Sometimes it will be fine, sometimes you will have to reformat or reinstall all over again.
Apr 19, 2016 | Acer Computers & Internet
Need to reset projector to factory default settings
hold the power button until it beeps or turns on ect but keep holding it and it should reset
Dec 07, 2013 | Acer X1261P - DLP projector - 3D - 2700...
Tablet dont turn on
Have you tried inserting a paperclip onto the reset hole?
https://acer--uk.custhelp.com/app/answers/detail/a_id/9154/~/iconia-tab-fails-to-respond
If reset does not work you can try factory reset (will ERASE your personal information currently stored on the tablet):
http://support.acer.com/acerpanam/tablets/2011/Acer/ICONIATab/ICONIATabA500/IconiaTabA500faq51.shtml
If the tablet will still not boot beyond logo if you decide to do factory reset then you should contact your nearest Acer support center:
http://www.acer.com/worldwide/support/service.htm
Good Luck
Jan 10, 2013 | Acer Iconia Tab A50010S32u Notebook
Acer aspire one reset to factory settings
Try alt+F10 when windows boot.
else try restart your computer start tapping F8 once you see the advance boot options..go to repair my computer..select the language..then enter your user name and password..in recovery options go to factory image recovery.
Sep 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Need factory settings aspire 5920
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operating, registry problems, virus problems, spyware issues and more. And a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
1.Back up all necessary data to an external device such as a disk, flash drive or hard drive
2.Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
3.Detach any external hardware such as an external hard drive or printer.
4.Press the Power button to boot your Acer laptop.
5.Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
6.Select "Restore System from factory default" in the Acer eRecovery Management window.
7.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
8.Click "OK" in the notice window to proceed with resetting your Acer laptop.
9.Wait while your Acer laptop is reset to factory settings.
Sep 06, 2011 | Acer Aspire 5920-6727 Notebook
Im trying to reset my acer to factory settings and evreything i try will not work. how do you reset the laptop to its factory settings
In order to reset your computer to factory setting you have to have the system restore disk and put it in your cd drive and reboot your computer with it inside... after pc boots up, a screen should popup click on restore to factory settings... if you dont have a disk reply back and i can give you a link for download..
Jun 10, 2010 | Acer Aspire 3000 Notebook
Reset Acer Aspire One to factory settings--clean hard drive
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Dec 28, 2008 | Acer Aspire One AOA110-1626 Notebook
Acer laptop restore factory settings?
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
Oct 19, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
Ekse
Alun Cox
