Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
Posted on Sep 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung 32in. model no. LE32R73BDXIXEU
Screen all one colour {greenish} no picture. Does not work on any input DVD or Aerial. Any Ideas?
electroman
Level 3:
Genius:
  • Samsung Master 1,039 Answers
  • Posted on Sep 01, 2009
electroman
Samsung Master
Level 3:
Genius:
Answers
1039
Questions
Helped
305128
Points
2353
Is there sound?Does the tv menue display? Likely main board. replace any swolen capacitors on power board first.
TV powers on but not picture. No input signal.
On the remote, you have a Source or Input button. Cycle through them. There is a source for every HDMI socket, plus aerial input. On my Samsung, that is 4 'channels'.
Try the same with a DVD running.
If nothing at all, you need a service centre.
The picture was fine when tv was linked to the BT tv kit. Now it's connected to the digitak aerial the picture has a pink/red tinge. How can I correct this? Thanks Gary L
Hi Gary. Not sure if this will be of any help, but have you tried connecting a DVD player and seeing if that is still colour tinged. It may be possible that your TV may have developed a fault and coincided with changing your aerial and there is in fact nothing wrong with the new aerial. I hope I'm wrong. If you are connecting through a different signal input socket, that may also be faulty or dirty. Basically, until someone can come up with a possible reason and fix, it may be worth ruling out other causes for the problems. Regards, Steve.
I have an onn 42 inck flatscreen tv and since last night have lost all colour on screen,,,tried cable and scart all seem ok,,any ideas
Hi.
If the problem happens using different input and devices, then it is either the terminal circuit (input/output connectors) or the processing unit in main board. The terminals are unlikely the culprit if problem concerns different inputs.
I imagine that the picture is not properly B&W (gray-shades) but some kind of reddish, bluish or greenish picture as the LCD will process picture using RGB (red green blue) channels instead of CYMK (cyan yellow magenta black) like CRT TVs.
Test the TV using an external aerial. You will notice if the channels have the wrong color even from static.
Use different inputs, different cables and different devices. beware of SCART cables, the SCART contacts are very easy to break. A defective cable will loose picture. Better testing using AV cables and component cables. AV cables are red/white for sound and yellow for video. If the two-wired yellow cable does not work, then the TV is faulty.
Other test can be done using component cables. Component cables send the three red-green-blue signals on different cables, hence testing is simple. Test swapping cables and see if TV tone stays the same if color tone changes the problem were the cables. Test also using at least two different devices (e.g. one DVD player and one TV receiver or a playstation).
If you find that the TV is defective call the manufacturer at the number listed on manual. If the problem is that one or more RGB channels do not work the TV main controller board must be replaced.
Regards.
Ginko
My Transonic LCD tv was connected to the aerial via my video recorder which is now out of order. I connected the aerial directly to the TV but now only get black & white! The DVD channel etc are...
Ok, if all you did was remove the vcr out of the circuit and put the aerial directly to the tv and now the color will not come in. That means your signal is not strong enough to provide a good picture. Some new model tvs have weaker tuners compared to older model tv and vcr tuners causing them to have weak snowy or black and white picture. The idea being most newer tvs are designed for cable or satellite hd use not for aerial use. What you wear doing before was amplifying the signal by running it thru the vrc first then viewing the output on the tv. Get another vcr or amplify the signal with an signal amplifier.
We have a black and white picture on the TV, no colour
check for DVD/TV cable. Use a SCART 21 conductor cable (if possible with gold contacts), or HDMI Cable if Tv has HDMI Input
Color is a problem. Screen picture has greenish
well it seems you have an issue with one of your video boards, it could be that the Analog Video Board (the one with the inputs and outputs) is partially damaged, but it can also be your Digital Video Board, which is the one that projects the image
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
1helpful
2answers
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
