Question about Navman ICN510 GPS Receiver
NAVMAN MAP UPGRADE
M7 AND SPEED CAMERA LOCATONS
  • 3 more comments
  • Anonymous Apr 03, 2008
    has any1 updated there 510
  • Anonymous May 29, 2008
  • churchx Nov 23, 2008
    No updates for any of the 500 series Navmans! New chipset, software, etc. so they can't do it!? Wha-a-a, did they fire all the people who DID do it a couple of years ago? Can/t they farm it ti a third party? Sure, they can do anything that they WANT to, and what they WANT is to sell you new hardware. BUY someone else's hardware if you have to!!
  • Anonymous Dec 19, 2008
    Navman has got to be the worst GPS on the market. Thier customer service is non existent. I am upset I cant get a map update not can you get any extra stuff like batters, cables or mounts.
    They **** bad.
  • Anonymous Apr 07, 2009
    never, never buy Navman, they are ****, trust me!!!!!!!!!!
  • 3 Answers
Navman in no longer offering map support for it's iCN 510. I am really mad about this. I spent $400 2 years ago for something that will not have anymore map updates. Here is there reply when I wrote to them about it. Class action suit anyone?
Dear Henry,
Thank you for contacting Navman Technical Support.
We do apologize for the inconvenience. Navman has decided not to release further map updates for these device due to changes in technology over the last year. We have changed the chipset and software platform and are unable to update this device. The Navman 500 series was released with an updated map version last 2005.
If you need further assistance, please do not hesitate to contact us, we'll be more than happy to help.
Kind regards,
Ofelia
Technical Support Team
Navman USA
C/O Mio Technology USA Ltd.
47988 Fremont Blvd.
Fremont, CA 94538
Office: +1 (866) 962-8626
www.navman.com
Posted on Mar 14, 2008
You paied 400 i paied 1200 when they first release it on 2005... i believe Tomtom is my next GPS system.
Posted on May 05, 2008
SOURCE:
Manual trunk release 2012 dodge charger
the operator guide missing in just 2 years.
did you look in 3 tops locatons
dash
glove box
side of drivers seat.
first
Jan 19, 2015 | 2012 Dodge Charger SRT8 Sedan 6.4L V8...
Panasonic m7 spare battery
A quick Google search lists many suppliers. As English isn't your first language I have searched for you and supplied 2 links.
NV M7 Panasonic Camcorder Batteries with free UK delivery
OEM Replacement Batteries NY
Aug 03, 2014 | Shop For Battery Cameras
Panasonic M7 VHS Camera
1.) set your pc to the correct norm (PAL or NTSC).
2.) if this doesn't help maybe you need to clean the head of your camera.
Take a short search on YouTube how to do it, there are dozens.
(NOTE: if you have recorded something with a dirty head you will not be able to play it back correctly even if after your head is clean!!!)
Mar 08, 2014 | Video Cameras
Problem with G31T-M7 Motherboard i have a ecs g31t-m7 mother and a intel e2200 processor. i try once to run my motherboard with a pentium d 820 and didnt run. so i put back my e2200 intel. the problem is...
sure go into cmos then set it back to factory setting there is a place to do that at the end at the top of your monitor esc key right arrow to last one on the right side down arrow set default then yes exit out
Apr 11, 2013 | Biostar G31-M7 TE Motherboard
Pendrive working slow....in biostar g31 m7 te
Go here and get the chipset driver:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=363&tab=3
May 19, 2012 | Biostar G31-M7 TE Motherboard
Need to know the Locatons for Vaccum hoses I have
Easiest way to find a vacume leak is to get some soapy water in a spray bottle and when engine is running look for any appearing bubbles that would signal a leak. All vacume hoses are simular in looks black rubber ranging in size from pencil to thunb in diameter. Vacume leaks are time consuming to repair and occasionally frustrating just be patient and listen with your ears.
A diagram will be in a haynes or chilton book for your year make and model you can get this at almost any auto parts store.
Oct 21, 2010 | 1998 Ford Escort
Replacing memory on the P4M800-M7 A motherboard
No. Just make sure that you two RAM modules have the same specifications (speed, clock).
If you don't know about that, then simply insert both RAM modules and start your computer. If Windows loads, then right click on MyComputer and go to properties. If it shows 1.5GB then you are OK.
If the computer fails to start or you hear multiple beeps it means that they are incompatible.
Replace the 512 module and insert the new one and try again.
Always remember to turn off the power and unplug the cable from the power supply before replacing RAM modules.
Jan 28, 2010 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Hi I also have a P4m800-M7 rev 3.1 motherboard and a 512mb of ram.. my question is, is it okay to put another ram but in 1gb size its pc3200, will it work? thanks!!
The motherboard supports 2GB maximum memory. 1x1GB in each slot.
Maximum clock speed is 400MHz (PC3200), so the memory module you have should work fine.
Please remember to remove the power cord before installing the new ram.
Regards.
Nov 25, 2009 | EliteGroup P4M800-M7 Motherboard
System won?t recognize SATA drive
No, the size does not matter. When you state the motherboard does not see the SATA drive are you saying the bios does not list the SATA drive? You're 750GB drive is most likely SATA 2.0 / 3.00BG transfer rate.
The P4M800-M7 does support SATA but it does not support SATA 2.0. So what you need to do to get the drive to function at a lower speed. Set to run Ultra 100/133MHz. You'll need help to do this. Try this software for Seagate. It might work for Seagate.
http://www.samsung.com/global/business/hdd/faqView.do?b2b_bbs_msg_id=126&orderNum=2
I haven't the time to research Seagates site for simular software.
However you can look through Seagate. Again you want to lower the SATA drive speed to Ultra. The bios will than see the SATA & so will windows.
http://www.seagate.com/www/en-us/support/downloads/seatools
Good Luck!
Mike
Jul 12, 2008 | EliteGroup P4M800-M7 Motherboard
P4M800-M7 presumed memory problem
I have never had a problem with Mobo's supporting 2 GB of memory.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&DetailName=Specification&MenuID=44&LanID=0
As per the website your mobo supports 2 GB memory.
Dec 25, 2007 | EliteGroup P4M800-M7 Motherboard
Navman ICN510 GPS Receiver Logo
4,013 people viewed this question
Top Navman GPS Experts
Ekse
Marvin
Marvin
Are you a Navman GPS Expert? Answer questions, earn points and help others
