Lands Phones Logo
Posted on Sep 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i return a call from caller id without dialing
How can i return a call from caller id without manuallydialing the number
RobertFonner
Level 2:
  • Expert 67 Answers
  • Posted on Sep 01, 2009
RobertFonner
Expert
Level 2:
Answers
67
Questions
0
Helped
22485
Points
206
On most phones, when you have the caller ID of the number you want to return a call to showing, just hit the talk button and it will dial the number.
1helpful
How to save caller id with name in panasonic kx- at7730
To save caller ID with a name in Panasonic KX-AT7730, you need to follow these steps:
Press the "Program" button on the phone.
Dial "9" to enter the "Caller ID" setting.
Dial "1" to enter the "Caller ID Memory" setting.
Dial the memory location number (0-99) where you want to save the caller ID and name.
Enter the caller's phone number using the keypad.
Press the "#" button to move to the next field.
Enter the caller's name using the keypad (use the alphanumeric keys to enter letters).
Press the "#" button again to save the entry.
Repeat steps 4-8 for each caller ID you want to save.
Note: Caller ID service must be enabled on your phone line for this feature to work. Also, make sure you have enough memory locations available in your phone's memory to save new caller IDs.
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
1helpful
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
1helpful
2answers
How do I unblock my phone number
After you enter *67, you hear the dial tone. Dial the outbound number. Your caller ID is not presented on the receiving end.
After you enter *82, you hear the dial tone. Dial the outbound number. Your caller ID is presented on the receiving end.
2answers
2helpful
2answers
How could i block my Cell Phone Number From Caller ID
  1. Just dial *67 before the phone number on your cell phone. This code is the universal command to deactivate caller ID.
    For example, placing a blocked call would look like*67 555 555 5555 (without the spaces). On the receiving end, caller ID will usually display "private number" because it has been blocked.
    Though you won't hear or see a confirmation of a successful caller ID block, it will work.
When a received call comes in the number shows 1-402 then the number.on call back the phone dials all 11 numbers,then i get a recording from windstream that says i dont need to dial the 1 and area code....
The caller ID in your area is set up to show the 1 plus the area code although not every area has yet to require you to dial the 1 before the number. In the near future it's possible you will have to dial the 1 even if you're calling a local number. I know of no way to change the phone settings in order to remove the 1 in the caller id. Unfortunately it looks like your only option will be to dial the number directly without the 1. Good luck!
14helpful
2answers
CALLER ID - REDIAL LD NUMBER
Press the caller id and get the number you want, then press the star button, that will add the 1 for long distance dialing.
2answers
Can't call out or answer phone
phone rigs once and i'm unable to answer the phone. Caller ID does not show the numbers all the time.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
