SOURCE: My Tv says Keys locked
PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
SOURCE: Car Alarm
sounds like the drivers side key switch has failed remove the interior door panel and there will be a switch attached to the back of the key lock cylinder or around there it should be two or three wires also check the door jamb wire harness where the door closes for any broken or damaged wires, use a vot meter and see if you get power or ground to the opposite side of the switch when you use the key to lock and unlock the door if nothing changes and there is power or ground! at this switch i would replace it, i don't think there is one but if the car has a passenger side key hole try to unlock the car from that side and see if you get the same problem -jeff
SOURCE: I have a RCA tv that has no remote and the front
I have rca tv with no remote and the fpa is locked...how do I unlock it?
SOURCE: how to unlock my APEX
Hello
It is impossible to unlock Apex TV without its remote control. If you have its remote control do this.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Ok
