Televison & Video Logo
Posted on Sep 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot get my sky guide to respond on my Loewe Articos 32,i think the kids have scrambled the tv remote! Any ideas?
Anonymous
Level 3:
  • Master 325 Answers
  • Posted on Sep 01, 2009
Anonymous
Master
Level 3:
Answers
325
Questions
0
Helped
184191
Points
1117
There are several things that can stop your Sky remote from working.
step one:
get a mobile that has a camera on it. point the remote at the camera and press the TV guide button on the remote you should see a little light by looking through your camera. This is because cameras dont like infrared
if you see the light whilest looking from the camera phone then the remote is working.
Step 2:
There can interfearance from devices like WII's or if your television has a back light you can turn this down and see if this is going to make any difference to the sky box.
If it does you know what is casuing the problem.
Step 3:
There may be another solution to your problem. Go onto Ebay and type in there Magic eye. you can get them from Argos but you will be paying 3 times if not more then you can get them off ebay.
once you've got the magic eye. plug this into the back of your sky box into RF OUT 2 this must be in 2 due to it providing 9v to the eye.
on your sky remote press services, 4, 0 1 select. go to Rf setting and turn this option to ON and then go down to save. you should see a little red light on the magic eye come on this is all done.
Now try your remote as normal.
I fit sky and a lot of the HD sky+ boxes have rubbish IR (infrared) so this sorts out a lot of problems.
Hope this helps
Little Dish Fitter
Loewe articos muffin fan stops..
If Fan stops running Lamp will not Light and TV will not come on!On your Menu you should have in there a listing for Lamp Timer it should tell you how many hrs you have on Lamp and Ballast Board is what turns Lamp on if you need Parts Call Encompass 1-800-638-3328 or UED 1-800-648-6657
1helpful
I have sound but no picture with my Loewe TV
Bad Ballast Board Call Encompass Parts 1-800-638-3328
Loewe articos hd tv rear projection. contrast too shiny
Try lowering Brightness first.Not contrast leave it up middle range.
Loewe articos 55
had same problem, solved by lamp replacement. back to full glory!
jurgen
Loewe Articos 55 HDTV loud buzzing noise
sorry cant solve it ,i called all the loewe service agents and they all said the same thing, put up with it. a new engine/colour wheel cost around $2500,
Tv turning off by itself
THE FILTERS IN THE BACK HAVE TO BE VACUUMED SO THAT THE TV DOESN'T OVERHEAT. THERE ARE 2 OF THEM IN THE BACK OF THE SET. USE THE VACUUM CLEANER HOSE WITH THE BRUSH ATTACHMENT SO NOTHING GETS DAMAGED.
1helpful
Loewe Articos 55 RP
There is a software patch that increases the cut off temperature you may get this at Loewe Website. Quick fix is reverse one of the fans on the back of the set this gives a through flow of air rather than all fans blowing into the set.
Help required
Call Panurgy in NJ - they've been retained by Loewe to provide official service to US owners. 1-866-563-9387
3answers
I have a loud "whirring" noise whenever the TV is on
it is actually the color wheel.Thepart an possibly ordered from andrews electrnic supply
Top Loewe Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
paul fairbanks
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
