Hi , i have a navman s50. the problem i have is when i turn it on it boots up to the point where you see the computer reaching the satellite however it dosent see the navman. please help.
15 of hearts
reflash the gps, or update your maps and you should be set! if nothing seems to work send in for warranty, what options does ur gps give you for connecting it to a pc or other device?
1. Connect Navman GPS to PC viamini-usb cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the 'Navman' folder
5. Open the 'Database' folder
6. Delete the following file only- 'dababase.db'
7. Close the folders
8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
Mine was doing the same. Navman advised me to hook up to the computer and access the unit in my computer,
find my documents on the navman and delete the logs. Worked for me. However now I have another problem and Navman don't know who to fix it.
The Nokia 6600 is not fully compatible with the S50. Check the Navman website for the bluetooth compatiblity. That model is not listed, Navman do state that not all features are possible.
Hi, my probelm is very similar I turn it on and it shows a laptop, usb connection and the navman with a usb cable connecting them together,it also has circle running back an fourth
My Navman S50 has been working fine the other day it decided to show me the safety agreement when switched on then shows half the screen black with navman S50 printed in the black section the other half shows a picture of a pretty womans face looking backwards from a car window. I can get to the main menu and then takes me in a circle back to the safety agreement I've tried resetting by holding the on off switch down for 6 seconds when switching off the device is there any other way to reset my navman S50.
