Samsung LN-S3251D 32 in. LCD HDTV Logo
Posted on Sep 01, 2009
Samsung tv sound but no picture
I have a Samsung HLP 5674wx/xaa and i have NO PICTURE and just sound , in the back of my tv there is a slight picture on the wall in the back of the tv ?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
579
Points
Solution #2 posted on Aug 15, 2009 samsung tv sound but no picture - 4%20ratings_thumbs.gif
noavatar_s.gif fastrepairs
Rank: Wiz
Rating: 88%, 28 votes
Make sure your tv is on the right input first of all. The newer flat panel2.gif lcds combine the componenent video (red , blue, green) with the composite video and audio (yellow, red, white). If your tv is on the component input then you hear audio from the composite input since the audio inputs (red, white) are shared. Look for a source or tv input button on your remote or the tv itself and try pressing this button unti you see a picture with sound.
I just used this information to solve the same problem...I ended up disconnecting the cable box and restarting the box until I got to the info panel for the box...the picture magicly appeared with several options. I picked one and problem solved...love the faq's on the search engine. lh in dak
My Samsung LNS4041DX/XAA audio is degraded
https://www.cnet.com/forums/discussions/samsung-lns4041dx-xaa-lcd-tv-has-sound-but-no-picture-513963/
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
My samsung tv LNT4669FX/XAA screen is blank but the tv and backlight work. how do i fix the tv?
It sounds like the screen may have failed, that means a new TV will be needed.
1helpful
Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
3answers
HLP 4663WX/XAA
sounds like the color wheel has gone out
Samsung LCD TV HCP4363WX/XAA Black screen no sound.
check out the link below ... sounds like a similar problem:
http://www.dslreports.com/forum/r20889230-Samsung-LCD-TV-No-Picture-but-has-Sound
1helpful
Replacement of bulb for my HLP 5674 WX/XAA
sounds like your lamp is needing to be replaced. www.alltvlamps.com will have the lamp for your set just enter the model number of your Tv to locate it.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
