Televison & Video Logo
n
nelson Posted on Jul 18, 2019
Good morning,I have a amely AD-UL101+S UNIVERSAL REMOTE CONTROLE. Can you help me to find the sharp codes tv . Thanks.
5 Related Answers
Anonymous
  • 97 Answers
  • Posted on Jun 20, 2008
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Anonymous
  • 97 Answers
  • Posted on Jun 21, 2008
SOURCE: Universal Remote Codes
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes the direction to forward again.
5. Press and release MUTE to install the code.
Herb Box
Herb Box
  • 117 Answers
  • Posted on Dec 08, 2008
SOURCE: chunghop universal tv remote codes
Chunghop Sharp codes; 044 054 119 124 196 198 225 227.
Anonymous
  • Posted on Oct 19, 2009
SOURCE: I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Anonymous
  • 4 Answers
  • Posted on Nov 27, 2010
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
How to activate universal remote control AMELY AD-UL101S with LG TV Brand or other brand?
Question edited for clarity and add maker.
No one uses Universal Remotes these day. You buy a Remote that is a Copy of the original.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
The AMELY is a very cheap and nasty Chinese Remote and they don't supply instructions!!
https://www.amely.cn/AD-UL101-S-AMELY-unviersal-TV-LCD-LED-remote-control-p636185.html
Codes are decided by the brand of television. This is for LG
https://www.google.com/search?q=universal+remote+codes+for+lg+tv
Necesito ayuda con un tutorial para progamar mi tv Sharp Aquos. Tengo un control universal Laxmax
https://www.google.com/search?q=lax-max+universal+remote
Sharp TV Remote codes, use the below codes to control your Sharp TV with a universal remote.
The 3 digit codes for most programmable universal remote controls for Sharp televisions are:
002
013
014
111
502
509
712
812
813
913
918
NOTE: Codes to operate televisions using a Sharp brand universal remote control will be 2 digits long. They will go from 01 to 18.
The 4 digit codes for most programmable universal remote controls for Sharp televisions are:
0039
0093
0165
0386
1004
1009
1011
1025
1064
1077
1078
1081
1097
1099
1153
1157
1274
1298
1311
1312
1362
1375
1378
3answers
Hi, I have a coby TV, and an AMELY AD-UL036 universal remote, how do I program the remote on my TV?
Use code search on your AMELY URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
I need codes for my RCA universal remote the model is RCU800B2445P
I am just trying to find for the RCA remote controle.Just need to code for a Sharp T.V
That all
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
