SOURCE: Blades won't engage on 23 hp 50
belt tensioner may need adjusting or the cutter head bearings may have seized,
SOURCE: I have a craftsman zts 7500 zero turning radius 26
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
SOURCE: Snapper Zero Turn mower. Blade will not engage. Any suggestions?
I am not sure what type of blade engagement mechanism you have (ex. clutch, tensioner/idler pulley, etc...) but make sure that the blades can spin freely with the belt taken off of their pulleys. It could very well be that one of the pulley bearings is seized.
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
SOURCE: TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
