A
Abraham Perez Posted on Jul 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sony model # MHC-V11 MAKES NO SOUND everything seems to operate but i cant get no sound from it
Don A
Level 3:
  • Sony Master 4,482 Answers
  • Posted on Apr 21, 2024
Don A
Sony Master
Level 3:
Answers
4482
Questions
5
Helped
1333115
Points
25791
Troubleshoot this issue. Here are some steps you can follow:
Check Speaker Connections:
Ensure that the rear surround speakers are properly connected to the Audio/Video (A/V) receiver.
If applicable to your model, verify that the A/B speaker selector is set correctly. If the speakers are connected to the A speaker connection, the selector must be set to the A position.
Test Tone Operation:
Perform a test tone operation to check if the speakers are functioning correctly.
Increase the rear speaker volume or adjust the surround speaker settings to the maximum level.
Speaker Size Settings:
Try selecting a different size (small or large) for the rear surround speakers in the menu.
Surround Sound Mode:
Verify that the A/V receiver is set to a surround sound mode.
For Dolby ProLogic surround sound, ensure that the center-channel mode is set to NORMAL or WIDE.
If your source is a DVD or Blu-ray Disc player, check that surround sound is enabled in the player's menu.
The audio being received must be multi-channel.
Different Surround Sound Mode:
Try setting the A/V receiver to a different surround sound mode.
Source Content:
Verify that the source you are playing is encoded in surround sound.
Note that during periods of mainly dialog, most of the sound may come from the center speaker only, with audio coming out of the rear speakers when there is background or ambient noise.
Factory Reset:
Reset the unit back to factory default settings (consult your operating instructions for model-specific steps).
If applicable, follow the steps for calibrating the appropriate settings automatically after connecting the calibration microphone device.
Speaker Wires and Replacement:
Check and replace the speaker wires if necessary.
Consider connecting a different pair of speakers to see if the issue persists.
If you've tried these steps and the problem remains unresolved, I recommend seeking professional service.
5 Related Answers
Anonymous
  • Posted on Jan 30, 2008
SOURCE: Sony MHC-2800 setting the clock
Hi, it's simple. First press "Timer1" and Timer2" buttons together, clock on display will start blinking, by cursors "Up/Down" you can change the value of hours and minutes (switching between hours/minutes by "Left/Right" cursor). To save set time press "Memory". Enjoy your set clock :)
Anonymous
  • 319 Answers
  • Posted on Aug 03, 2008
SOURCE: no sound
Make sure speakers are still good and not blown
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Jul 27, 2009
SOURCE: no sound
Change the audio amplifier IC
Anonymous
  • Posted on May 06, 2011
SOURCE: Hi, my Sony MHC-RG444S has a strange buzzing sound
Anonymous
  • Posted on Dec 13, 2011
SOURCE: My RMF-GD001 operates everything except the tv. I
I had the same problem.
My Bravia LCD TV wasn't responding to its remote RMF-GD001 although the remote works on the home entertainment unit. Lucky for me, I have an extended warranty and so I called for a service. Technician tested my remote and said that it's RF transmitter is spoilt. Little did I know that the remote has IR and RF transmitter and it will work on any devices that uses infra red transmission. But Bravia LCD TVs use the radio frequency transmission and that is where the problem is.
I had my $125 remote replaced FOC. :)
This reminds me to get a silicon case for the remote and to put it out of reach from my kids who like to drop things.
Sony MHC G88 Hi-Fi music system not delivering sound to speakers thru RCA
tell all things connected, and did not(in detail or photos)
what are you plugging in.(all)
I can buy endless speaker systems and no 2 are the same.
no speakers told, (hardwired, amplified, or what?,)
bad speakers, or bad RCA cables.
bad RCA output jacks on rear of g88 (preamps bad)
or PC end failing,
if I knew all you had there all makes and models and connections exact told , I can in fact tell you tests to do.
2answers
Sony mhc gt444
http://www.sony.co.uk/support/en/content/cnt-specs/MHC-GT444/list
According to this there is no midrange unit! So you don't need to open it. If the sound is coming from the tweeter and bass it's OK.
1helpful
System is running but no sound
You want sound to system when system running?the sound of computer is produced by the fan inside cpu.is there was no sound that is good to your system.
My speaker outputs, including headphones, makes a loud pulsing sound. the stereo is a sony mhc-rx70 bookshelf system.
It is mobile phone system's problem, you can try to mobile phone shop where to install system. Instead of Stereo Earphone problem.
1helpful
My Sony TDM-iP10 ipod port wont charge my ipod
The media adaptor is not fully compatible with the latest ipod. If you add a Scorsche adaptor to the set up, it will facilitate the charging.
Sony mhc-GX450 mech error
unplug the system.take out any extra speakers,and try plugging it back in.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
