I can connect an external antenna and I can scan and receive channels, When I hook up my cable box through all of the ports in the back I get sound but no picture. I tried to hook up my cable minus the box and scan for channels and I did not get anything
Hello Eweber touch the screen with your finger and see if you can see light behind your finger on the screen if you can this means your backlight is working and the problem is more than likely coming from the inverter board which is faulty and has to be replaced, if you can not see any light this could be a faulty backlight or inverter board, in most cases it is the inverter power supply which turns out to be the faulty one, thank you hope this helps.
