Televison & Video Logo
Cinnia Galve Posted on Jul 18, 2019
How can i fix my mediacom speaker... it is not functioning but they have a power .. only blinking light appear and the HI is also blinking.. the remote is also not.functioning
1 Related Answer
brian williams
  • 1980 Answers
  • Posted on Sep 11, 2016
SOURCE: TV remote light & tv power indicator light are both blinking continuously. Cannot move cursor on the remote.
Check for a stuck/pushed in button or try and remove/reinsert batteries.
Got an Element TV and my Mediacom remote wont control volume
Is the mediacom classed as a "universal remote", or one from another device?
If universal, such as "One4All" type, you should be able to Google the code set for the Mediacom.
If device-specific, then only certain functions may work (if you're lucky).
Clive.
Model LC-465B57U flashing power light and opc light
Hi Tracy,
It appears your TV is not sequencing properly. By the order given in your instructions with the controller you are tuning, continue with a code until it satisfies .
Press setup- blinks twice. Enter TV manufacturer code- press enter. Light should flash once. Press on . After it works . Go through all the functions. Up- Down, loudness, channels,& on -off .
Fare .Well.
Hi, I have a sony bravia 46v400a. When turning the power on, green light appears then switches off, then red light flashes 6 times. I read somewhere it could be a speaker voltage problem. I then...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Uei mediacom remote cbl buton keeps blinking
Just take out the battery out from its battery compartment, and re-insert it. Try to program it after that.
Will not reset, light blinks 8 times
Hi there you can try this
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
All The Best Pineworks
Dishwasher not responsive, just a blinking CLEAN light.
HI, this is a control fault that is located in the logic sector of the circuit board. You will need to replace the control in order to restore proper function.
1helpful
3answers
Display gone, no longer functioning
Green light but no display- most likely main transformer is gone (60%), 35%- blown main fuse, 5%- bad display or power supply. You are lucky if unit is still under warranty. Solution- repair shop.
2answers
Denon AVR-1905 Receiver
Hi again,
Any new developments?
2answers
Power light Blinking Fast/No Sound
check your speaker wire or speaker, for short circuit.
1helpful
4answers
Blinking standby light system will not turn on
I was having a similar problem and determined that there was a short in the speaker leads for the center channel speaker. The leads to the speaker were touching, after being moved, slightly while housecleaning. Once short was eliminated, unit powered on and worked with no problem.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
