I have a chocolate fountain that runs & heats but it does not spin. When I turn on the heater it works when I turn on the part that rotates it makes a noise like it's rotating but does not rotate.
Is this fixable or should I buy a new one?
Thank you,
~Betty
It's Nostalgia Electrics 3 teir 1.5 Amp chocolate fountain....which is not found on the list below.
SOURCE: I lost mu instruction manual
i bought the popcorn cart and its been over an hour and has not popped a kernal. the oil is hot I do not know what is going on
SOURCE: I need instructions for Chocolate Fondue
Most of this machines have a bowl at the bottom, and 2 or 3 plates above it with a tube in the middle, if it does look like this first melt some choocolate and put it in the bowl at the bottom. dont start the machine yet!! fill the bowl to about 1 cm under the top of it, then turn the machine on, after a few (1 - 10) seconds the chocolate comes out on the top of the upper plate and pours down over the plates below it, back into the bowl underneath it.
SOURCE: how much oil do you put in with the chocolate?
Experiment with it. Start with just a little oil and periodically add more until it flows properly. Be sure it sets up when it gets cool, if it doesn't you have to much oil.
Good Luck,
Gilshultz
SOURCE: need procedure for using nostalgia electrics kpm-508
Here is a link to Nostalgia Electrics..Fill in their form and you can go from there. Here is the link...
http://nostalgiaelectrics.com/default.asp?a=service copy and paste it into your browser or try to click on it..Hope this helps you..Wayne
SOURCE: center rotating shaft broke
Amazon have
some smaller chocolate machine models; http://www.amazon.com/s/ref=nb_sb_ss_i_8_10?url=search-alias%3Dgarden&field-keywords=chocolate+fountain+machine&sprefix=chocolate+%2Cgarden%2C266&rh=n%3A1055398%2Ck%3Achocolate+fountain+machine
Or http://www.bestbuy.com/site/Specialty-Appliances/Chocolate-Fountains/pcmcat194000050030.c?id=pcmcat194000050030
Chocolate fountain machines have become very popular lately at parties and events. They are basically fountains that have liquid chocolate running out of the spouts. Usually fruit, marshmallows etc are placed on sticks nearby and guests can dip their chosen item into the flowing chocolate. It's pretty cool.
