HP Photosmart 3180 All-In-One Printer Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Weird noise from printer carriage
My printer starts to warm up and then it makes a loud clicking noise coming from under the carriage. Then the check paper light comes on. There is no paper in the printer or a paper jam...help plz!!
steveparlin
Level 2:
Scholar:
  • Expert 61 Answers
  • Posted on Sep 01, 2009
steveparlin
Expert
Level 2:
Scholar:
Answers
61
Questions
0
Helped
34577
Points
152
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
HP D5145 printer makes loud clicking noise
These units use plastic gears and when they start to wear, you can have noises like you describe. It could also be something on the carriage system for the print head.
2helpful
4answers
HP 2410 Photosmart All in One Printer
the clicking sound is coming most likely from the printhead carriage, if you open the printer so you can see the cartridges, is the carriage stuck? trying to move to a direction and makeing the sound?
1helpful
2answers
My 2001 tahoe makes a loud clicking noise in forward motion. The faster you go and the warmer the vehicle is it goes away. Then in reverse it makes a loud scraping noise. Help plz.
how well does reverse work and check color and level of trans fluid with engine running and warm also feel for grittyness of fluid if gritty and browning your trans may be going out
2answers
After switching the printer on it gets ready to print and I hear the usual sounds, I persume the ink cartridge carrier moving but recently it has started making a loud chattering sound for a few seconds...
First of all, check to see if you also hookup the phone cable to jack too? If yes, temporary unplug it to see if noise goes off.
Also, open the lid to check on the drive belt. It may be loose and not able to drive the carriage. There is the gear on the right side of the carriage and a pulley on left side of the of the carriage. The spring which holds the pulley tight might be broken. Check that to see if it is the case. If it is that is why it makes loud noise when printing. And if it is not fixed, eventually you will receive an error message and printer will not work.
Check that and let me know.
Thanks
3helpful
My HP Photosmart C4280 All in one is all of a sudden making a loud clicking sound when I print. It just started doing it when I printed the next page.
>an unusual noise in the printer could be problem with printing mechanism or a carriage is jammed, try this steps about carriage jam and see if this will resole the issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01309787&cc=us&lc=en&dlc=en&product=3192753
Making a loud noise when the paper is feeding.
This is what the HP website says about noises in the 1610..
Issue Unexpected noise (clicking, thumping, grinding, squealing, and so forth) from an HP all-in-one can be caused by a problem with the ink carriage or the scanner. Solution Follow the steps below in the order presented to determine the source and resolution for the noise. Step one: Checking the scanner This step applies only to products equipped with a flatbed scanner.
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
Step two: Checking for paper feed problems and carriage blocks Click here (buu03110) (in English) for more information on paper or carriage jams. Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. So it sounds like it needs to be serviced which could get expensive. I've looked all over the web for you & Keep finding the same answer. Sorry I can't come up with a better solution for you.
1helpful
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
1helpful
Loud banging noise
encoda strip at the back of the carriage has come loose locate it and place it back be careful as if the strip breaks so does your printer.@ hope this was helpful
2answers
SHARP AL-1641CS
If there is a clicking chances are a gear has gone out. It should be checked out be a technician.
Roller stuck
you may have simply just dislodged the feed assembly, remove your tray and inspect the under carriage, its a start and see for anything out of place...
k24674
Grand Canyon Tech
Grand Canyon Tech
