We have a 3 year old Whirlpool double oven (AccuSystem). The display in the control panel went out over night and it just beeps when you push a botton - nothing happens. Tried to cut the main power to reset it, but it didn't help. What's wrong?
Control went blank on whirlpool oven
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
I have double ovens and the control panel went out about a year ago. My son's marble also hit the bottom glass door and shattered. I had sears come out and they ordered the door that my husband installed to save money. The repair man showed my how to take out a connection in the control panel and take an eraser to it. He warned me that it wouldn't last long. My control panel beeps and flashes codes "E6-F1" & "E2-F1". I put off replacing the control panel. If I remember correctly it was around $300.00 or more. I'm looking for a cheaper price. I miss my ovens.
Has anyone resolved this problem with the control panel going blank--the only button left working on our double unit is the one for the light and that's it.
I reset the breakers and studied the manule which is mostly useless.
Thanks.
Whirlpool gas oven can't come on. Control panel not working
Our power went out for 2 mins last night and now our oven has no display showing. The light is on in the oven and the buttons 'beep' when pushed.
The sab bath is on the control panel screen and noe of the push bttos will work. the eye on the atove work ok, it is only the oven that seems to be locked up.
I have a SFPA395X. We had a blackout, the power is now back but the clock is flashing with the wrong time. I can't access the menus when i press the controls nothing happens. Please help me reset the time and get the oven working again.
The double oven does not heat up for both up and down oven. There is no error display on the control panel.
power when out now cannot reset my oven contrls
