Question about Konica Minolta PagePro 1390MF All-In-One Laser Printer
When trying to fax I get an error "open adf cover"...
I have a Konica-minolta pagepro 1390mf and am trying to send a fax. When I try to feed the paper at the top, it says "open adf cover, remove the paper" then I have to scan each page, one at a time with the cover open. Can I fax with the cover closed through the top?
    Scholar:
  • 118 Answers
You should be able to. It sounds like you've got a paper jam in the document feeder. Chances are there was a jam and part of the document (a small peice perhaps) is still lodged in the document feeder unit.
Posted on Aug 31, 2009
6ya staff
SOURCE:
Why am I getting an error message on my PagePro 1390mf?
what is the error message??????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 29, 2014 | Konica Minolta PagePro 1390MF Laser...
How can i rewrite firmware without usb connection on Konica Minolta PagePro 1390MF
Telephone the nearest authorized KONICA supplier, and arrange for a service-call to fix your device.
Mar 15, 2011 | Konica Minolta PagePro 1390MF All-In-One...
It said to open from cover and remove paper I did and It dont work
If you receive an "Open front cover" error message the solution is to open the cover and remove the paper and any remnants of the paper jam. If there is no obvious paper remnants jamming the printer and you continue to receive an error message I would suggest unplugging the printer from the power source.
After 5 - 10 minutes plug in to power source.
Turn on printer.
See if this has resolved error message. If not you will need to check more carefully for paper remnants that would be causing the printer to detect a jam.
Trust this is helpful. :)
Dec 08, 2010 | Konica Minolta PagePro 1390MF All-In-One...
My Konica Minolta 1390Mf says open front cover and remove paper, but there is no paper inside please help
Normally when you get a remove paper jam and there is no paper, it is because the paper didn't make it out of the tray. Open the front door and remove your toner/drum unit. If you look inside you will see a gray half circle roller, try cleaning this roller with mild detergent. Do not use alcohol, this will dry out the roller.
Apr 14, 2010 | Konica Minolta PagePro 1390MF All-In-One...
Hey i have this konica minolta PagePro 1300W printer. Problem is: i need a printer driver for vista(64bit).can anyone help?
Go to www.konicaminolta.com usa and download a driver PagePro 1300W or 1390MF the driver might say for windows. I have PagePro 1390MF and it work with usb connection.
Mar 13, 2009 | Konica Minolta PagePro 1300W Printer
Top ADF will not recognize paper in the feed tray.
Try to replace the 'paper is present' sensor with the 'cover open' one to see if now it is detecting the paper. Also, check the actuator that enter in that sensor.
Jan 16, 2009 | Konica Minolta bizhub 161f All-In-One...
Error Message: Open Front Cover and Remove Paper: There is no Paper
Try reaching around the back, you'll notice a rounded tab pointing
back from another door on the print unit--you can pop this cover up
and close it. That reset the error for me.
Jun 23, 2008 | Konica Minolta PagePro 1390MF All-In-One...
Konica Minolta PagePro 1390MF All-In-One Laser Printer Logo
337 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
