if you replace all the burners will this solve the problem? My stove does not stop clicking and I have to unplug it and can not use my oven. THe repair job will be close to $900--is it worth it or should I consider a new stove?if you replace all the burners will this solve the problem? My stove does not stop clicking and I have to unplug it and can not use my oven. THe repair job will be close to $900--is it worth it or should I consider a new stove?
You can't post conmments that contain an email address.
If your unit is already old enough, I think it will need to replace many parts. So it is worth buying a new one than to repair it because many parts will be replaced soon. I hope I give you some idea.
Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
I have one of those that I got as a wedding gift from my parents in 1975. They were popular then. My mother had always come out with nicely warmed buns, but when my wife and I tried to use ours, our buns were soggy--from too much water, I guess.You have to use it on top of the stove, not in the oven. Try putting in about a half-inch of water and put in the middle piece. If it floats, then you have too much water. Put the buns inside, place the lid on, and put it on low heat for 2-3 minutes. You can regulate how soft or crisp the bun would be by opening the steam vent for more crispy bread, or closing it for it to be more moist. You can experiment with it, but yes, you DO need to use it on TOP of the stove.~ Barry
There are any number of resources on the Internet that may have this part, although it may be that the manufacturer of the oven made this a non-replaceable part.
In searching the WP website, they don't offer the element for aBT0BR0040 , so unlikely they ever provided one for the BT0BR0050 . Not surprising with these perceived high quality/low cost built appliances.
The only thing else I would suggest is to see if you can even get the old element out. If you can, then there might be a chance.
Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
