You may call or find a machine expert, as it is not a Big issue and the best option can be, you may contact DALHPIH customer service for your help.
If you require CNC Machine from the best manufacturer at an affordable price, then Visit Superior Machinery.
Check to see if the shaft are true and straight.
What is the problem with the bearings. Axial runout? Horizontal runout? What shafts or parts do these bearings go to? If it is shafts, are the shafts straight? Bearing surface in good repair on the shaft? Do the bearings fit correctly in their bearing mounts? Did you preload the bearings if required? How did the bearings get damaged?
