Question about Kitchen Ranges
I HAVE 5500 CARVER I HAVE JUST CHANGED THE SLIDER CONTROL TI TWIN KNOB CONTROLS GAS IS WORKING BUT ELECTRIC DOES BUT USED TO ON SLIDER ?
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
alandc
  • 28 Answers
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
Posted on Jan 31, 2009
revskank
  • 203 Answers
SOURCE: Logitech z-5500 control pod
http://cgi.ebay.co.uk/Logitech-Z-5500-Control-Pod-FULLY-WORKING-Unit-Panel_W0QQitemZ180332248253QQcmdZViewItemQQptZUK_Computing_DesktopComponents_RL?hash=item180332248253&_trksid=p3286.c0.m14&_trkparms=72%3A1700|66%3A2|65%3A12|39%3A1|240%3A1318
Posted on Feb 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven ignition: gas goes out as soon as control knob is released
Replace the oven thermocouple.
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: our carver 5500 turbo fanmaster
hi looking for a slid control for a carvar 5500 turbo fan master heater
Posted on Oct 25, 2009
My carver 5500 fanmaster mother board under the sliders is broken were do i get one from please.
Try tailoring the broken board by soldering all the dry joints ,getting a new one is only by buying a new amp.
Sep 28, 2016 | Carver Audio Players & Recorders
Why is the thermostat temp. range reading 30 degrees lower than it should be
Thermostat controls are nothing but variable resistors. Sometimes they build corrosion in the metal tab that it is sliding on. First try rotating the knob back and forth several times full range. If it is a slider instead of a knob, move it up and down full range. (This should be done on a regular basis.) If that does not work then shut the power off to the unit and get some contact cleaner. You can buy it in any electronic store. Spray the contact cleaner into the back of the control and work the knob full range again. It should feel easier to turn after a few turns. This should do the trick. If it doesn't, you need a new thermostat.
Feb 04, 2016 | Kitchen Ranges
How do i clean balance slider and pots?
Sliders are easy where-as pots are not. SLIDERS - provided you insert the "tuner/control cleaner w-lube" extension nozzle past the plastic dust/dirt shield, a few "spurts" of spray, removing nozzle extension and then move control back-n-forth will clean the control. POTS - you MUST shoot tuner/control cleaner in the small slot adjacent to the electrical connections (inside the unit). Removing knobs and spraying the control shaft never works as the shaft-body seal is an extremely tight tolerance. Check here for a view of the pot.. http://en.wikipedia.org/wiki/Potentiometer
Mar 31, 2015 | Audio Players & Recorders
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
I cant get my knobs or sliders on my oxygen 49 controller working keys, octave and mode and pitch work fine, its just the sliders and knobs
Here is a link that might help:http://www.m-audio.com/index.php?do=products.directlink If your DAW isn't supported it might have a learn function that might help. Make sure you download the latest update.
Oct 18, 2010 | M-Audio Oxygen 49 USB Midi Controller
Carver 5500 turbo fanmaster keeps blowning the
its sounds like you have a sort some where, if you have a compressor , or the heater element could be bad? slide heater out to see if there is a burnt wire
Apr 11, 2010 | Heating & Cooling
Carver stereo amp will only play
That should be normal. The main inputs usually go directly to the power amp. If you want volume control, put a mixer with faders beween them... Radio Shack used to have some inexpensive mixers.
Mar 09, 2009 | Carver PM950 Amplifier
Car radio volume control knob is erratic
When I turn on my radio, the volume is on and o.k. but when I try to turn it higher or lower the volume is lost completely. Any comments?
Jul 06, 2008 | 2001 Pontiac Aztek
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
