R
Roger Posted on Jul 18, 2019
Presets on radio fo Gemini map 3000 - Gemini Audio Players & Recorders
Why does the SiriusXM Tour radio keep losing preset favorites?
It sounds like your SiriusXM Tour 360L radio is having difficulty saving your presets. The issue may be related to a problem with the internal memory or a software issue. You can try resetting the radio to its factory settings and reprogramming your presets. If the issue persists, you may need to contact SiriusXM support for assistance.
Jbl radio A56840 loses station presets and no volume
Toyota vehicles have a fuse in the kick for the amp and sometimes there is located under the hood ... This is the switch turn on for the amp ... And 1 of the fuses is most likely the memory or constant power. B sure to check all fuses ... I do not have AllData pulled up . If the fuses are all good the amp or radio may be bad ... Or both ... Be sure to check all the fuses ... Many times I get clients that say allthe fuses are good and it is still the first thing I check ..Usually is a fuse ..Good Luck
Gemini amp shut down while spinning
Could be power supply related- failing capacitors being most likely.
Could also be PWM failure- Failing capacitors being the most likely.
Output may have shorted out, or the MOSFETS or IGBT's may have failed.
2helpful
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Gemini xga3000 led protection is on all the time what's wrong?
Likely have damage in the amplifier... probably the output stage. It will require servicing.
2helpful
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Ford 3000 radio code
1. Drivers door open - leave open.
2. Ign. ON. - Use RED key only.
3. Radio ON.
4. Press and hold presets 1, 3 and 6.
5. Ign. OFF then back ON within 1 second.
6. Release presets 1, 3 and 6.
7. Radio OFF.
8. Ign. OFF.
http://forum.gsmhosting.com/vbb/archive/t-121123.html
Check that post above there are a few?
1helpful
Gemini Sound Products EQ-3000 equalizer
please connect as the following-----1-mp3 out-----to cd in in your receiver.
2-receiver rec out (tape put)----to equalizer in.
3-equalizer out----to tape in in receiver.
2answers
Radio
you kind of dont mate sorry. press the option button and hit 'autoscan' it then finds all usable radio signals and presets them. from there you use the normal song controls to switch between presets. also after you have the presets set, you can go to the options manu of a preset again and then name it.
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
