Yes, it does! If you have dropped your phone in water, completely submerging your SIM Card and Phone in rice will cause the rice to absorb the water in your phone. Your phone will work after a couple of hours of being in rice.
If there is still water in the phone, get a bowl and put some dry rice in it then the phone then cover the phone with rice and make sure it is completely covered. The rice will pull the water out of your phone. Leave it in as long as you can, preferably over night. You could also put your phone and the rice in a zip lock bag. It's more portable.
First of
all, do not turn it on, it could cause more damage to your phone. Take out the battery, and
completely dry the phone
before trying to use again.
Here is the procedure to take out all moisture
trapped in the phone: Dry the phone, battery, any accessory, etc. with
cloth and wrap each piece, phone and accessories, in newspaper. Place
a few handfuls of rice into a plastic bag and then place the wrapped
phone in
the bag with rice. The newspaper wrapping avoids direct contact of rice
with your phone because
the dust from the rice can get into the small areas of
the phone. The newspaper and rice will absorb moisture. Leave it there
(with
the bag open) at least 24 hrs. Hope this helps!
Did you dry
the phone completely? If not here is the procedure to take out all moisture
a few handfuls of rice into a plastic bag and then place the wrapped phone in
with your phone because the dust from the rice can get into the small areas of the
phone. The newspaper and rice will absorb moisture. Leave it there (with the
Did you dry
the phone and battery completely? If not here is the procedure to take out all moisture
trapped in the phone: Dry the phone, battery, sim card and any accessory, etc. with
Did you dry
Get a bowl of rice. Remove the battery from the phone. Leave the phone back open. Put phone and battery in the bowl of rice, cover and leave overnight.
The rice will hopefully soak up any water inside the phone and battery. If this doesn't work there may be permanent damage to the phone from the water and charging afterwords.
