My stove has an F7 and a flashing E9 error codes displayed on the control panel. Do I need a new control panel or display membrane, or possibly both?
Well first of all you determine if problem is with the Key Panel or Control by-
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC).
Post comments for more help or information........
Good Luck!!
Hello, i was able to clear the error just as easy as unplugging the unit for 3 minutes and slapping the junk out of the top of the unit above the key pad. Hope this helps thanks.....
