Being that old, it probably does not exist. The best you can do is get a circuit diagram, then plan you own locations and power wiring. Usually on the roof you will find a AC unit which requires 110volts ac, sometimes a 12 volt DC fan or two for kitchen or generally air cooling to exhaust hot air or circulate air. You may have a TV antenna on the roof needing RG 59 coax going to it.
SOURCE: Coleman Mach roof top ac
Under the drain pan on each side should be a small plastic drain plug they might be clogged up with debris.
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
SOURCE: WIRING DIAGRAM FOR 1984 AMC EAGLE
well you have several options you can go to a dealship and have them copy the diagram for you(i do this all the time) or you can purchase a repair manual at Napa or Oreilly's for around 20 bucks. it has diagrams and schematics in it. it also has alot of instructions in it so you can do repairs yourself. By the way i'm surprised that the mechanic doesn't have these diagrams himself. I was wandering why it won't start after you changed the plugs and wires could it be that maybe the firing order is wrong. i've done that myself a time or 2. double check the the plug wires to make sure they are in the right spot. if the problem is it won't crank. chances are you have a loose ground. please rate this..thanks
SOURCE: i need a wiring diagram for fog lights oem to my toyota
The link below is a Typical fog lamp / driving lamp hookup. Keep in mind that in most states, for these lamps to be 'legal' (and thus pass inspection), you must wire them such that:
1. You can cut them off (in other words, there must be a switch installed to turn them off)
and
2. They may only be operated with the low beams. (therefore, you must power your on/off switch from the low beam circuit)
http://www.accessconnect.com/fog_driving_lights_wiring.htm
SOURCE: air is not very cold on a rv roof top ac what
You should have the manual for this unit handy and as far as recharging tools go. You only need a can of R134a *(if the unit is R12 you need to buy upgrade adapters since R12 is no longer sold) Run the unit and put the R134a filler line on the low pressure side of the compressor *(from manual...dont guess as trying to charge the high pressure side is VERY dangerous). Get the charge just into the Green zone on your charger and that is it! Try not to fill too high in the green zone....I know it sounds funny...but AC's usually work better when they have the low end of their optimum fill. R134a doesnt work as well as R12 so be sure you buy the R134a with cooling enhancers. Your local Autozone can guide you to the right filler/product combination.
Good luck and be careful!
