Insignia portable air conditioner: The air conditioner will turn and the vents open up to blow air out, then the vents close and the unit blinks an FL code. There is no water in the unit .
SOURCE: air conditioner not blowing cold air
go to a parts store such as Advance Auto Parts or Auto Zone and buy the A/C recharging kit they have with the rubber line and connector that connects only on the side that you need to recharge your system. If you can put air in your tires you can out freon in your a/c system.
SOURCE: 2003 Trailblazer Air Conditioner fan runs but no air out vents
Mine does the exact same thing. If I turn it off for a few minutes it will work again for about 15 minutes. Doesn't matter which area I select the air to come out. The fan blows hard but very little air comes out.
SOURCE: Cold Air Not Blowing Through Vents
Your last guess is probably the right one. The deflectors/directors are vacuum controlled and you may have vacuum line either broken or disconnected; these aren't fun to find. I would start under the hood and make sure the vacuum reservoir is intact (have seen them cracked) and then start tracing hoses from there.
Testimonial: "ellent advice and responed very quickly. Thank you."
SOURCE: Blowing water out the vents.
There is a water pipe from AC to outside,
if a lot of gel inside the pipe, it can make water flow become jam.
Clean it by blow the pipe with a compressor from outside.
Sometimes I did it with my mouth. LOL......
But its worked finally.
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
