Question about King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width, Model No. Tg - 72 - Y
Just bought a 6 ft king kutter brush hog - no owner's manual with it - need to know how to set the braces can I download a manual?
  • 496 Answers
I took a stab at this... I hope this is what you are looking for:
http://www.kingkutter.com/downloads/manRKRK.pdf
Posted on Aug 31, 2009
    President:
  • 1,126 Answers
Http://www.kingkutter.com/
Perhaps you can find it here? Hope this helps.
SOURCE:
How do you change blades on 5ft bush hog?
lift The brush hog up and place on blocks or other foundation that wont fall over. disconnect the power take off shaft from the tractor. Now look for two round openings in the middle of the deck one on ether side of the gear box (the thing on the brush hog that the pto shaft from the tractor hooks up to to make it spin there might be a slip clutch on the shaft but go to the box in the middle) Now turn the shaft till you see the blade nuts in the hole These could be castle nuts with a small carter pin locking them so they don't unscrew. Remove the pin and with a large socket set unscrew it from the bolt then knock the press fit bolt down and the blade will come off, do the same to the other blade if you need them both off. To put them back on use something under the blade and bolt to hold it up so you can start the nut then reverse the order and put everything back on. The blade bolt might be stubborn to get out just take something that fits through the access hole like a wood doll or long punch and drive the bolt down till it comes out as it is press fit and is jammed up to keep the bolt from turning, when putting it back on you will need to make it tight so the bolt can repress back in. Be Careful when reaching under to set the blade and bolt back in. There is not much you can mess up it is just a big nut and bolt Just make sure you put the blade on the way it came off if you do one blade or one at a time you can look at the other to see which way it goes.
Oct 02, 2014 | King Kutter Rotary Tiller Pto Bush Hog...
I have a King Kutter brush hogger and am having trouble getting it connect to the New Holland tractor. The man who connected it for me last year is no longer around and the man I hired could not get it...
You are talking about a three point hitch ... they can be tricky. Might be worth the time to go to the farm supply store in your community and take a look at how it should be hooked up and operated. It is dangerous to operate this device with out some training.
May 03, 2011 | King Kutter Garden
Is the King Kutter ATV SeederSpreader suitable for applying lime? If so what setting shoud be used? Thanks, Doug (Giles County, VA)
lime should be applied at 50 lbs per 100 sq ft which is heavy mark off 100sq and see what it takes at 3mph
Jan 29, 2011 | King Kutter ATV SeederSpreader 350Lb...
Hi - recently bought a new KingKutter 4ft bush
go to kingkutter.com and download the manual.
hatter1
May 15, 2009 | King Kutter Pull Type Rotary Kutter 72in....
King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width, Model No. Tg - 72 - Y Logo
685 people viewed this question
Top King Kutter Garden Experts
Jay Finke
Jay Finke
George Merkley
George Merkley
john h
Are you a King Kutter Garden Expert? Answer questions, earn points and help others
