Lg Veiwty- battery died, so i charged it, still wont turn on
Ive charged it fully and it just wont turn on. It comes up ''Charging Battery'' and i have taken the battery out and put it back in, but it still wont work.
The optimus black phone should take 2-3 hours to fully charge. When you get a new phone, however, it is generally a good idea to let the battery completely die before you start charging it.
Over time, batteries hold less and less charge. Supposedly, by allowing the battery to completely die before charging it the first time, you improve the longevity of the battery.
You could load test the battery ,to see if its good ,if it is good or new,it may be your stator,or charging system.You could check the voltage of the battery while its running to see if its charging. I found ,they dont like not being started,or sitting for awhile. Ive installed a battery tender ,that keeps my battery fully charged even if you let the bike sit for extended periods of time. Its a very low amp charging system ,then turns itself on and off,to keep your battery fully charged. Sometimes there called Float chargers too.
I had a similar problem with a brand new LG Xenon. The battery charger said it was charging but the phone didn't charge. When the battery life on the phone died the phone would not turn on with the charger. I plugged it into my USB port on my laptop and the phone fully charged for real. I got 4 days before I had to recharge it again. Try USB cable to a PC to charge phone. Charger is probably bad. I am getting a replacement and will see if that works.
From your description of the problem, it appears your phone's battery needs to be replaced. Because of the danger of damage to your phone from a bad battery, you should replace your battery immediately.
Your phone does not allow recalibration of your battery - as battery consumption is preset from the factory.
As the phone keeps turning on off there is some loose contacts or some dirt is there at battery terminals try cleaning phone and battery contact terminals
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know. Thanks, Lee
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
that's not the battery prob bro...check ur mob charging pins...i have the same prob with my MDA but when i squeeze my pins of MDA its working...so do the same...i hope this work...and also check ur friend battery on ur mob with charger..
