SOURCE: coleman mach air
Time for a spring cleanning,, especially the drainnage system, filter,, front cooling coils-and the drain line! thank you-very-much!
SOURCE: coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know [email protected]
SOURCE: Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
SOURCE: I have a Mach III. Unit blows hot air and bogs down when cooling.
probably (90 %) the compressor's bad, depnding on the repair cost you probbly want to just get another AC unit
