Uniden Cordless Phone Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Uniden cordless phone with answering machine, 900 mhz model number exa 122801. How do I adjust the ringer volume?
Anonymous
Level 3:
President:
  • Master 1,126 Answers
  • Posted on Aug 31, 2009
Anonymous
Master
Level 3:
President:
Answers
1126
Questions
0
Helped
563483
Points
3418
Http://www.uniden.com/index/manuals_results.cfm?cat=1
I can not locate that model number, please verify. Hope this site helps.
How do I turn down the ringer volume.
For the base station set the ringer switch on the base from high to low. To turn it off select off. You can find that switch on the panel where the phone plugs into the wall on the far left.
The handset is adjusted the same way on the leftside as you are looking at the phone.
2answers
1helpful
Uniden cordless: Adjusting ring tone volume down
If it is like mine....push on one of the volume buttons (up or down,doesn't matter) and the phone will ring. WHILE IT RINGS, push the button again and it should scroll to the next ring option. Keep pushing WHILE it rings to scroll through the ring options.
I can not find my manuel. How do I turn on the
Adjusting the Ringer Volume
You can choose from four ringer volume settings on the handset (off, low, medium,
and high). With the phone in standby, use the up arrow or the down on the handset to adjust the
ringer volume.
You can find your manual online in PDF format here:
http://www.uniden.com/pdf/TRU9360om.pdf
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
How to adjust ringer volume
Yours is a little different from mine, but maybe this will help some, I hope. On the "talk" side, there is a button (2nd from right on mine) which says "loud" over the button, and "ringer" under the button. Pushing the button once gives you the soft ring. Pushing the button again will give you the loud ring. If you have gone to the loud ring, you will get the loud ring on the first time. Then you can push it again to get you back to the soft ring. I hope this helps.
Uniden Phone Problems.
You can find the manual here:
http://www.uniden.com/pdf/EXAI3248om.pdf
The information you're looking for is on page 40.
2helpful
Change ringer from lo to hi
Do you know the model #? If so, you can get the owners manual from the the uniden website. Here is a link to the page so you can look for your specific model number. Just click on your model number and it will load the pdf format of the owners manual.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
