SOURCE: voice mail notification to cell phone
This is a phone system phone. What you are looking for would be a feature of your voice mail that is connected to the phone system. "Handsfree Speakerphone- 3-Line Back Lit display and 24-Line Keys. Compatible with KXTDA200 and KXTDA100 Systems. " Sounds like you either have a KX-TDA200 or KX-TDA100 phone system. Usually voice mail is an optional feature and has a separate part number. You could also have voice mail service through your phone service provider (like Verizon) Do you have any user guides for your voice mail or one for your phone that covers voice mail features? If not, the first step is to find out for sure what you have for a voice mail. If you have a working message waiting light on the phone it would be an in-house voice mail connected to the system.
SOURCE: How to set time on Panasonic KX-T7633
From the system administrator's phone, enter programming and dial 000 and follow the prompts using the FWD and CONF button to move the cursor back and forth.
Carl
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
SOURCE: panasonic KX-T7633. trying to send calls to
From your phone did you dial the *7105 command for call forward busy/no answer? You need to add the voice mail box to the rest of the command followed by #.
SOURCE: Panasonic KX-T7633 Notification Light will not turn off
The red light is MESSAGE WAITING. It is not necessarily VM notification. Press the MESSAGE button and look at the display. One of the soft keys will let you CLEAR the message and it will tell you where it came from. It's set by anybody calling your phone, and randomly, it is set by dialing your extension plus "4". Oops. It's a Pana mystery :-)
Carl
You are asking about changing you voice mail and phone system settings. Your phone can work on several different Panasonic phone systems and you could have different voice mail systems as well.
The phone KX-T7633 has only a user guide that covers the basic features of the phone itself. You need a programming and installation manual for your phone system AND your voice mail. They are not the same part and have different manuals.
So, your first step is to find out the model number of your phone system and voice mail system.
