The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
When moving/storing Laser printers, its suggested that you remove all Toner Carts prior to the unit being moved. The Toner "Dust" (If you will) will settle in the bottom of each cartridge, and become compact. (When LJ's are used on a normal basis, the toner is tumbled around like clothes in a dryer).
Sometimes just turning (Shaking?) your toner carts will help the toner flow better in the drum.
