Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each Logo
Posted on Aug 31, 2009
The battery is fully charged but the scooter will not move.
The scooter will not move when switched on - there is a constant beep.
  • 1 more comment
  • Anonymous May 11, 2010
    Try not touching the leavers on the colum while incerting the key.
  • Anonymous Mar 22, 2014
    Lark 4. The scooter just stopped and now refuses to move. The beeping is constant. There is no drive at all. Battery is fully charged and all lights are working. What could the problem be?
  • Anonymous Mar 29, 2014
    batteries fully charged scooter drives ok for a few yards , stops, switch off and on, scooters drives for a few more yards, then fau am unable to access a manual. help me please.
    lt idicator flashes and scooter stops. the flashes six times repeatedly. I
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Sep 22, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
5176
Points
29
Is it the small portable scooter? The one with the base that comes apart for transporting? Could it be a bad connection where it goes back together?
If it is the portable, try disconnecting the rear drive portion from the base and re-installing it so it clicks into place.
2helpful
2answers
TGA VITA S constantly beeping but moves
hi Ruben,, if it sounds like the horn button is pressed maybe not that loud , then you got water in the horn button that is conducting , carefully take a hairdryer and warm the button etc and I mean warm not hot!, remember its plastic ..
if it's a beep pause beep and so on, it the scooter telling you the batteries are low ...
regards
Rob
When switched on red light is constant but as soon as I try to move the light flashes constantly, no pauses.
Hi get you're batteries LOAD TESTED to check there condition .U can buy a load tester on E/BAY FOR aprox $30 to $35 this will give U an accurate test on there condition ..good luck
Amobility scooter
Hey Barb,
The beeping sound is a beep code, the freewheel lever needs to be put in drive.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
My gogo ultra is showing fully charged and horn beeps, when i put key in it beeps fast 10 times and 5 beeps after
5 beeps usually means scooter is out of gear, but since the lever is in the drive position and the scooter gearbox/differential is engaged, it seems that the controller is not sensing the gear change. Possibly a faulty micro switch in the motor housing can be the cause of this, usually the micro switch is pressed down by the drive lever and if the switch is pressed down the motor controller knows the scooter is in gear.
2answers
My battery is fully charged but my scooter wont go?
hi, how many bleeps before a pause ? or is it constant bleeping ?
This error can be caused by a bad connection , check where the back end comes away from the frame...
Regards
Rob
www.gewizrepairs.co.uk
1helpful
2answers
Battery shows fully charged and the horn beeps but it won't move.
I have the same problem in mine.. But the beep is continous. Mine is a fortress 2000 AT. anybody knows what's the trouble on this one?
1helpful
Gogo elitescooter lights indicate battery fully charged but scooter will not go
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
We have charged the battery and when we turn on the scooter all it does it make a beeping sound and the scooter will not move
So the Battery charger is showing a green light (Fully Charged ?) Can you tell me the MAke and Model of the Scooter ?
Top Drive Medical Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
