Question about Hisense Televison & Video
My hisense tv turns off when I hook an hdmi cable up to it to view my pc on it.
Go into input or source change to PC
    Top Expert:
  • Hisense Master
  • 10,097 Answers
Posted on Aug 10, 2019
SOURCE:
SOURCE: Protron HDTV Cable hook up
D4 is a Japanese HD standard, which is why it's almost impossible to find any cables with a D4 connector on it in the US.
I have the same Protron TV you're talking about, but it's been rebranded as Ultra. Did you not receive a D4 cable when you bought the TV?
If not here is where you can get the cable you need: http://www.igsshop.com/product_info.php?products_id=162
or here
https://www.digitalconnection.com/store/Product_List.asp?CID=3&CAT=D4%20SCART/COMPONENT
This should allow you to get HD signal from your cable box (granted you have an HD cable box) to your TV.
Posted on Dec 31, 2007
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
welcomejee
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
zlittell
  • 30 Answers
SOURCE: Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Posted on Aug 03, 2009
How do I connect my acre laptop up to my hisense tv using a HDMI cable
For most laptops with present day systems and software, it should be a connect-and-go process. Just hook the cable into the laptop's output and the TV's input. Make sure the TV is set to the input channel to receive HDMI. If the sound still comes through the laptop speakers, you'll need to go into the laptop's sound settings and configure it manually to put the audio through the HDMI cable.
If your Acer laptop has an older system like Windows XP, you'll need to use hotkeys or manual display configuration from the laptop to set its output to HDMI. Some laptops don't automatically recognize when they've been hooked up to a TV and will need to be told.
Jan 30, 2018 | Hisense Televison & Video
I have a 52" hisense tv and when u turn it on it shows the hisense pic then goes black no pic or sound after that can anyone tell me what it is or how to fix it
probable bad connection to video source, cable,satellite try a new video cable, Other then that , you may have to check your TV source setting and select proper feed HDMI 1,HDMI 2, cable, etc.
press the helpful button and give it a try.
Hisense Smart TV unboxing and set up review
Jan 16, 2016 | Televison & Video
New 50" hisense tv .. unable to use hdmi for cable box .. tried different cables and all 3 hdmi outlets on tv ????
There might be a setting on your cable box for audio output. Use the cable remote and look in the audio section of the settings menu and select HDMI output. Mine is under Audio Digital Output in the Audio/Video menu.
Feb 21, 2015 | Hisense 50 Class 1080p LED Smart HDTV -...
Hisense tv is stuck on retrieving data, then goes to no signal. Desktop is hooked up to it.. desktop was working with hdmi before
I had the same problem right up until the HDMI stopped working altogether. I had to use the ''component'' cables instead. The problem in my case is a bad HDMI socket (circuit board). The word ''randomly'' caught my attention. That's exactly how it happened with mine.
Jan 01, 2015 | Hisense 40" Smart TV Full HD 1080p LED...
My h8sense tv does not to work with a HDMI cable
you evidently have a problem with your h8sense MAIN PCB.
Oct 16, 2014 | Hisense Televison & Video
32D20 connection problems
You could have a HDMI cable that has gone bad; FYI, HDMI cables carry both audio and video signals.
Regarding the "Not HDCP Compliant" message: http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection
Dec 28, 2013 | Hisense Televison & Video
IWhat's your problem? I have a Hisense LTDN42V68US LCD TV and I am trying to hook it up to a Phillips HDMI DVD Home theater surround system HT53544 my problem is I am not getting a sound I only get so
Good day!!!
Your problem is on your digital cable signal or connection..
Please check all the wirings and connection from the to cable box..
its better if you re insert all connectors and restart all TV,cable box....
Hope it helps...
Dec 06, 2011 | Televison & Video
How can I view my pc on tv using an hdmi cable and a comcast digital cable box? My tv does not have an hdmi input.
The hdmi port on the Comcast box is an output only and cannot be used as an input from the general public. If your tv has a DVI output, there are DVI to HDMI adapters that can make the hook up....other than that, there is the super video cable but you will still have to run audio through a seperate line.
Oct 11, 2009 | HP Pavilion dv9000z Notebook
Televison & Video Logo
29 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
