Panasonic KX-T7630 Corded Phone Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SMDR I want to set SMDR with my new PABX KX-T7730. The computer can not detec usb cable
Carl Navarro
Level 3:
  • Panasonic Master 2,460 Answers
  • Posted on Aug 31, 2009
Carl Navarro
Panasonic Master
Level 3:
Answers
2460
Questions
Helped
1155764
Points
7314
Is that USB to Serial? I guess you'll need to find the drivers for your device. After that, you can use a standard serial cable and either a call accounting package or hyperterm to capture SMDR.
Carl
Panasonic KX-T7730. Why can't I receive calls?
Probably, the problem is not on your phone it is on your PABX configuration. Please advise your IT Guy to check your PABX or perform a PABX reset.
Normally all thes phone call the standard ext 101 if they want to make a call but I am trying to set direct lines for some of them so they ll not have to call the standard whenever they need to call . ...
you have to do that in the pabx setting where by you set all out going calls to be calling direct but all incoming calls to be calling to the switchboard first so change the call restriction feature
How to program the PBX through panasonic KX-T7730 handset
i want to reset my pabx machine and programm it all by kx t7730 by my self how i can pl plz
PANASONIC KX-T7730 HOW CAN I SET DOT MATRIX PRINTER TO TAKE CALLER REPORT MY PRINTER IS EPSON LQ-300-II before we using our hotel reception same this model printer now recently that printer repaired we...
SMDR requres a couple of things, a serial printer, a special cable outlined in the installation manual, and programming. It isn't a "free" solution or a step-by-step process. If you have the TD installation and programming manuals, start with the SMDR features description and the SMDR printer pinouts. It will give you detailed pictures and places to program in the system. IIRC there's a pin on the DB-25 side that you absolutely have to tie to another to make it work.
Carl
I am using kx-t7730 set with pabx kx-tem824 for programming purpose. My question ia that how i programme the 10 memory button of the set it self.
The 10 memory buttons are the first 10 buttons on the right side of the phone bottom to top. They are shared and left over from the old 70xx series. So, just program the right side buttons (PROG button dial your number STORE) and you can access them by pressing the buttons or using the keypad.
Carl
How do I update the time on the panasonic kx-t7730
that is not pssible to set from telephone
there is a PABX device (panasonic kx-tes824 ) fixed in wall
from that PABX check 101 extension number (maybe 10, wich phone connected jack1 )
from there is only you can program
Please let me know this useful
2answers
I would like connect kx-t7730 to tda100 .can I connect it ?
Yes. However, it will only work if you have the 8-port hybrid card(TDA0170) installed. Besides costing a lot more money(the card, not the phone) the phone uses 4x the power of a 76xx or DT series phone and you only get 12 lousy working buttons.
Carl
KX-T7730 Problem
Try to delete both or reseting to phone settings
4helpful
2answers
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
