How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
  • 4,281 Answers
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Posted on Aug 31, 2009
SOURCE:
How do i turn off mac filtering on my netgear wndr3300 rangemax dual band router through my computer/
MAC address filtering is configured in the wireless settings.
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 24, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I want to set up my wifi dvd player to one of the wifi connections and leave the other for my lap top. don't know how to use both of the wifi connections.
This is NOT a DVD player. The Netgear RangeMax Dual Band Wireless-N Router WNDR3300 features a rather misleading name. The router doesn't support true dual-band wireless-N, nor does it offer very good range. It's a basic router with two separate access points (AP), one of which supports Wireless-N and can operate in either 2.4GHz or 5GHz frequencies--similar to the D-Link DGL-4500--while the other is a regular 802.11G 2.4GHz-only AP. The result is that when in dual-band mode the router is able to offer Wireless-N only in the 5Ghz frequency, while the 2.4Ghz frequency is maxed out at the 802.11G speed. Still, if you have a growing stable of 5Ghz-based devices and want a router that supports both frequencies, the WNDR3300 is the cheapest router on the market (at about $100) that will suit your needs.
While its max throughput is relatively low, the router offered very consistent and considerably high throughput speeds on both our mixed-mode and long-range throughput tests. Unfortunately, its range is possibly the shortest among Wireless-N routers. If range is not important to you and your network primarily consists of 5GHz-based clients, the WNDR330 is a good bet. Otherwise, for the same price, we'd recommend the 2.4GHz-only Linksys WRT310N; or you can pay $50 more for the true dual-band Linksys WRT610n.
Dec 27, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Netgear dualband wndr3300 - Why can I only connect to one band
Dual band means it is working on both 2.4Ghz and 5Ghz frequency. If your computer can connect on both frequency that only means that the wireless adapter in your computer is also dual band.
Jan 26, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
How do I connect my Arris TM502G to my Netgear WNDR3300? I go through the setup and it says error cannot connect to the Internet. I need help.
Please let me know who is your internet service provider(ISP)
then i can give you instruction how to setup router
Happy to help
Thanks for using Fixya
Jan 17, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
NetGear WNDR3300 RangeMax Xbox Live Failure
Follow the below steps to configure settings on the router:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a Password in the passphrase box. Apply the settings.
Scan for the wireless network on the XBOX and connect to your network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 27, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
WNDR3300 RangeMax Wireless N Router. I forgot my Network username and Password. How do i reset?
i did download the sofware of the ARES ULTRA and cann,t connecting to the internet
Jan 15, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Computers & Internet Logo
258 people viewed this question
Alun Cox
