I have a Htc p3400.I m from Orissa so how to config bsnl gprs in my phone.I have tried but i want good setting or solution. I need help from the experts pls help me friends..(BSNL GPRS IN ORISSA)
You can try refering to their online documentation which is very clear ... the link is here....
Click here for Automatic GPRS/WAP/MMS Mobile Handset configuration
Click here forGPRS FAQ www.ap.bsnl.co.in/mmsgprs/wap.asp - Similar Good Luck!!
by your no., it seems that you're a subscriber od bsnl UP-E.. you can do the settings as mentioned here > http://www.bsnl.co.in/wap-web/dsn.htm & do the settings by start > settings > connections > connections > Add a new modem connections..
Hi for the GPRS setting you have to add a new connection by going into the settings menu and after that for server and port information you have to contact BSNL customer care as they only would be able to guide you regarding server and port number and after that you can connect to internet using EDGE available in your phone.
i am elamurugu. i connect the htc mobile with bsnl cellone GPRS as following method. ies
go to start
go to setting
go to connections
in this go to connections
go to gprs setting
go to Add a new modem connection
go to General Enter a name for these setting as: BSNLGPRS Setting
Select a modem as :CELLULAR LINE (GPRS)
Next
Access point name: GPRSSOUTH.CELLONE.IN [as i am tamilnadu bsnl south zone]
Next
User name: YOUR CELLONE NO 94**********
Password: YOUR CELLONE NO 94**********
Finish
go to Proxy setting
select [tick] This network connects to internet
select [tick] This network uses a proxy server to connect to the Internet
then go to Connection Setup
Select Operator
Country: India
Operator : BSNL
then OK
Do you want to continue?
Yes
finally RESTART YOUR DIVCE
say YES.
Afer restart you can now use bsnl gprs.You have note a symbol at top of your htc mobile as E or G.
If you have problem to connect bsnlgprs With this correct setting call cellone customer care about this or call me
