To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control
system.
OSD OPTIONS:
Contrast increases or decreases
display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu.
Color opens the
Color
Manager menu.
Language changes the display language for the OSD control system.
User
displays information
about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
My monitor has the vertical deflection ok and when you turn it on, for a period of time it looks ok and you can watch it perfectly, but when you open a video window, the lines appears.....You can watch de video, but with some lines jumping on it.....If you close the video window, the lines could dissapear or decrease.......I have also noticed that the position of an open window on the desktop, results in an increase or decrease of the number of lines, i.e., when you drag the window to different positions on the screen, the horizontal lines tend to form on the edges of the window and move with it........I hope this could clear my problem a little bit....Thanks once again for your help......Im witing for more comments......Thanks.
My monitor has the vertical deflection ok and you can watch it all the time....but when you open a video window for instance, horizontal lines appear on it...You can watch the video, but with the lines jumping on it, depending of the images of the video.....I hace also noticed that when you open a window, the lines appear on the edges of the window from side to side of the screen and when you drag the window to other position, the lines move with it....When you open a window with many folders, it looks that the level of details increase on the screen and that triggers the apperance of more lines......Sometimes when no windows are open you can watch the screen perfectly and you dont notice any lines.....I hope these comments clear my monitor problem...Thanks once again....I hope you can help me solve this problem......Thanks...
